Date/Time: Mon, 24 Feb 2025 01:21:10 +0000
Exporting Continuous Futures Contract Charts
View Count: 1647
[2013-06-29 06:26:29]
User42282 - Posts: 41
Hi, is there a way how to export Continuous Futures Contract Charts? Since there is not a possibility of replay, I had an idea of exporting the chart and importing again. Thank you.
[2013-06-29 23:50:59]
This can be done indirectly by using the Spreadsheet study and then saving the price data in the leftmost columns as a text file and importing it. Here are instructions for the Spreadsheet study:
http://www.sierrachart.com/index.php?l=doc/doc_StudiesSystemsAlerts.php
[2013-06-30 20:10:00]
Yes, thanks, I am aware of this possibility; but as far as I understand you can not output tick data this way? For 1 minute chart it would work.
[2013-06-30 20:10:54]
You can if you set the chart bars to 1 trade per bar. If you have a lot of days loaded, this will take a lot of memory though.
[2021-02-28 00:47:49]
gr93 - Posts: 18
Is there a way to do it if SC gives an out of memory error?
