Date/Time: Tue, 15 Sep 2026 15:44:11 +0000
GetCorrespondingMatch for dates
View Count: 1104
[2016-02-12 04:29:46]
rhovega - Posts: 279
Hi SC,
In Trading Spreadsheet Study I would like to reference the high/low of the trade entry bar for stops placement. Having gone through this http://www.sierrachart.com/index.php?page=doc/doc_SpreadsheetFunctions.html I believe the only function capable of that sort of search is the GETCORRESPONDINGMATCH function. Yet it only works with numbers, not with text nor dates/time.
Would you know of an alternative way to reference the high/low of the trade entry bar? If not, would you consider modifying the GETCORRESPONDINGMATCH function for it to accept dates/time as input?
Many thanks
[2016-02-12 11:48:24]
A Date-Time is a number:
Spreadsheet Functions: Serial DateTime Values
There are various functions to create the number.
[2016-02-14 00:20:18]
For reference of anyone else looking into this, GETCORRESPONDINGMATCH combined with value(cell#) as input worked.
