Date/Time: Sat, 28 Dec 2024 09:14:49 +0000
Using the free trial
View Count: 1618
[2016-02-11 19:49:40] |
Gettinmoneybruh - Posts: 2 |
First time using this software, on the free trial right now. I did check the FAQ before posting but couldn't find a solution so here goes: my chart doesn't update on its own I have to right click it and select delete and download data and even then its not real time but 10 or so minutes delayed. is this because its on a trial? if so doesn't the trial give full real time service? thanks |
[2016-02-11 20:35:33] |
A trial definitely does not give a full real-time service. We do not understand why users are expecting that with all of the controls over market data from exchanges. You can get real-time Forex and CFD data by using the Forex and CFD symbols. Did you want real-time futures data? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-11 20:36:04
[2016-02-11 20:45:20] |
Refer to this page: What is Included in the Free Trial? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-11 21:04:23] |
Ok thank you, yes it was futures that I was looking at
[2016-02-11 23:13:42] |
For CME futures data, you can get 2 weeks for 5 USD. However, before considering that, who is your futures broker? For the reason why we ask this, refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CME Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
