Date/Time: Fri, 21 Feb 2025 18:26:19 +0000
Volume Alert
View Count: 2039
[2016-02-11 19:00:56] |
wingz - Posts: 121 |
Can you please point me to the text that will tell me how to set an audible alert for different amounts of volume on the volume study, per bar, on a 1 minute chart. For instance............if volume reaches 8000, on the current bar, I would like an audible alert to sound. If volume reaches 10,000 on the current bar, I would like an audible alert, etc.
[2016-02-12 23:13:12] |
Refer to Alert Formula example 29 here: https://www.sierrachart.com/index.php?page=doc/doc_StudyChartAlertsAndScanning.php#FormulaExamples Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-01-21 15:20:45] |
User471027 - Posts: 19 |
Is there also a way to have the alert not with regards to the the entire candle volume but with regards to a particular price level? E.g. give an alert when the volume at a particular price level exceeds 180.
[2021-01-21 15:31:16] |
John - SC Support - Posts: 38111 |
There are special functions to be able to access the volume at a specific price point for Alerts. Refer to the information here: Study/Chart Alerts And Scanning: Special Functions For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
