Date/Time: Fri, 27 Sep 2024 07:21:57 +0000
premiums and market stats
View Count: 712
[2016-02-11 16:39:21] |
TradingMarketProfile - Posts: 120 |
hello, I don't get acces to premiums symbol like $INX for exemple. The same for $VIX in indexes $INX = white screen Do i need to ask you to activated or can you tell me what do i need to do to get it i already paid to get the sierra data feed Thanks |
[2016-02-11 17:48:33] |
Refer to the documentation here about the Cash Indexes: Sierra Chart Exchange Data Feed: Cash Indexes You need to activate the exchanges these are on. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
