Date/Time: Fri, 27 Sep 2024 07:21:13 +0000
S&P 500 Cash Index
View Count: 1875
[2016-02-11 16:23:18] |
User574084 - Posts: 1 |
Hello, I am unable to get live updates on the S&P500 cash index. I use amp trading and I am enabled to get the S&P500 index through CQG. However, the intraday data is not updating. I do not see this problem with other charts like the Emini's. |
[2016-02-11 17:49:54] |
We are not sure what the CQG symbol is for the S&P 500. If you know what that is and use it, it should work properly. You can also access the cash indexes using the Sierra Chart data feeds: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#AccessCashIndexMarketData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-11 17:50:13
