Date/Time: Fri, 27 Sep 2024 07:17:17 +0000
Inquiry on number bar function on package 5
View Count: 741
[2016-02-11 02:58:13] |
User157806 - Posts: 71 |
Had a question on the number bar feature. On a chart with Numbers Bars is visible the last candle/numbers bar as standard on right side. Is it possible to see on right as last bar to be pulled back from this last candle? I know the Pullback is there on the chart but just want to avoid the constant scrolling. How can I make the pullback constantly visible as the last bar? |
[2016-02-11 18:00:27] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#FillSpace Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
