Date/Time: Sat, 28 Dec 2024 08:53:50 +0000
Trade window on chart
View Count: 654
[2016-02-11 01:59:15] |
User157806 - Posts: 71 |
I just had a general question is it possible when detaching the trade window from the chart to rotate it? For example I would like to rotate it 90 degrees when it is detached.
[2016-02-11 02:13:02] |
No, this is not supported.
