Date/Time: Fri, 27 Sep 2024 07:20:02 +0000
Bundled/Unbundled with CTS for CME Agriculture
View Count: 1062
[2016-02-10 21:19:27] |
User515694 - Posts: 2 |
Hello, can i ask, Bundled/Unbundled with CTS not working for CME Agriculture? Example for Soybean? For CME Currency - is fully ok! Many thanks!!!!!!! thank u very much! |
[2016-02-11 03:14:22] |
This could be. This is controlled by CTS. Make sure you are running the current version of Sierra Chart and you have the option to unbundle trades in Global Settings Data/Trade Service Settings. This is all that we can do on our side. Whether unbundling trades is supported for a particular market, is controlled by CTS. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-11 06:09:40] |
I have sent a letter to CTS: > Hello, thank u very much! SierraChart is implemented selector bundled/unbundled. > Can i ask, which market inside CME supporting it? > For example, CME Currency - yes, ok, but CME Soybean - no. > where i can get the list of supporting markets? CTS response: > All cme markets support it. > Cheers > Andrew > Can u comment it? this is bug, or Soybean not CME market? with respect, Anthony Date Time Of Last Edit: 2016-02-11 14:00:46
