Date/Time: Sat, 28 Dec 2024 09:01:44 +0000
User Email
View Count: 699
[2016-02-10 20:00:48] |
Sierra Chart - Max - Posts: 5770 |
In the attached screenshot there is a spread between the bid and ask (at prices 2839 and 2840). He is asking if it's possible to correlate this spread to the Time & Sales window? At the moment, he says this shows up in the DOM only, not the T&S. Sierra Chart Support |
Time and Sales.PNG / V - Attached On 2016-02-10 20:00:45 UTC - Size: 303.21 KB - 281 views |
[2016-02-11 02:21:45] |
A correlation is not supported.
