Date/Time: Sat, 28 Dec 2024 09:03:51 +0000
BACK TESTING
View Count: 853
[2016-02-10 13:58:22] |
User82615 - Posts: 106 |
HELLO I'M TRYING TO BACKTEST A TRADING SYSTEM BUT AFTER INSERTING THE TRADING SYSTEM IN THE CHART AND CHOSING THE OPTION OF AUTO TRADE SYSTEM BAR BASED BACK TEST IT DOESN'T SHOW ANY ORDER IN THE CHART. COULD ANYBODY TELL ME WHY THIS BACKTESTING IS NOT WORKING ? THANK YOU VERY MUCH |
[2016-02-10 18:38:13] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_Backtesting.php Is this a spreadsheet or ACSIL trading system? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-10 18:47:35] |
THANK YOU I ALREADY SOLVED IT , IT WAS BECAUSE I HAD THE SEND ORDERS TO TRADING SERVICE IN "TRUE" IN MY ACSIL TRADING SYSTEM AND THAT HAD TO BE IN "FALSE" FOR THE BACK TEST SIMULATION. THANKS FOR YOUR HELP ANYWAY |
