Date/Time: Tue, 07 Jul 2026 04:19:58 +0000
Scrolling too slow, when empty space to the right
View Count: 1290
| [2016-02-10 08:16:48] |
| phaedonk - Posts: 352 |
I have set the scroll multiplier to 20, because I want to be able to scroll fast along history and find the relevant price area. However, when the chart is not at its end and there is space to the right, scrolling is extremely slow, until the window fill with bars. And then its fast again. Can you make it that it maintains the same speed, regardles of space to the right?
| [2016-02-10 10:55:48] |
This will not change. This is by design. Not sure of the reasoning, but it is something that definitely will not change. What you need to do to solve this to do what you want is lock the fill space: Working With Charts: Right Side Fill Space Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-10 10:56:03
