Date/Time: Sat, 28 Dec 2024 09:11:10 +0000
Interactive Brokers "Record True Real Time Data" but still update with snapshot data
View Count: 2197
[2016-02-10 02:17:24] |
User705691 - Posts: 22 |
Is it possible to Record True Real Time Data for the candlesticks so that the data is accurate, but at the same time STILL be updating the candlesticks using the snapshot data? This way, we can have the candlesticks being updated faster than every 5 seconds and still have the candlesticks being corrected every 5 seconds.
Date Time Of Last Edit: 2016-02-10 02:28:16
[2016-02-10 02:42:44] |
No it is not and we would not do anything further with this anyway. What symbols are you tracking? Consider using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-10 02:51:41] |
I am trading the Nikkei 225 Mini futures contract on the Osaka Securities Exchange, as well as stocks on the Tokyo Stock Exchange, so it wouldn't be possible for me to use the Sierra Chart Exchange Data Feed. I have asked in another support thread about CQG data for the OSE and TSE. Thanks for the help.
Date Time Of Last Edit: 2016-02-10 02:52:55
[2016-02-10 20:02:27] |
We heard from CQG about this and you will need to open an account with a broker supporting CQG and also supports trading those particular exchanges.
