Date/Time: Sun, 13 Sep 2026 04:46:37 +0000
Trading with a different broker
View Count: 1071
| [2016-02-10 02:06:38] |
| User972044 - Posts: 154 |
Hi there, Is it possible to use the price data of one broker, say FXCM but actually trade with another broker let's say, IB? Thanks |
| [2016-02-10 04:42:34] |
Yes. Refer to: Using Multiple Data and Trading Services at the Same Time However, it is not that simple. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-10 05:19:31] |
Ok if I am connected to IB data service, what happens to Sierra Charts and my automated trading system when IB shuts down its TWS for its daily maintenance at 5:00 PM EST? Does Sierra Charts crash? Would my automated trading system automatically get disabled? That's my only concern and that's why I am inquiring whether I can be connected to another data service while trade with IB through Sierra Charts as it seems FXCM doesn't have this daily interruption at 5:00 PM. Thank you. Date Time Of Last Edit: 2016-02-10 05:20:34
| [2016-02-10 05:39:36] |
Sierra Chart will just lose the connection and continuously try to reconnect. Obviously when Sierra Chart is not connected to TWS, no orders will be sent and we would not expect your automated trading system to be trying to send orders anyway. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-10 05:57:23] |
But would my automated trading system still stay enabled during the disconnection or does it get disabled and I would have to enable it again once Sierra Charts is reconnected to TWS?
| [2016-02-10 06:04:42] |
It will remain enabled. Refer to the documentation here: Automated Trading Management: Automatic Recovery of Trading System After Restart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
