Date/Time: Sun, 27 Sep 2026 09:20:07 +0000
[User Discussion] - SC arrays and Median price
View Count: 1054
| [2016-02-10 01:42:18] |
| User972044 - Posts: 154 |
Hi there, One of my indicator would need to use the median price. Is that available from Sierra Chart and how do I use it in the ASCIl, SC_MEDIAN or sc.Median? Also can I have a list of all the SC arrays? So far all I know is SC_LAST, SC_HIGH and SC_LOW. Is there any others? And also what's the difference between SC_LAST and sc.Close? Thanks |
| [2016-02-12 23:06:42] |
Last and Close have the same meaning. The sc.HLAvg array is the midpoint of the bar. You can find more details here: ACSIL Interface Members - Variables and Arrays Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
