Date/Time: Fri, 25 Sep 2026 03:39:31 +0000
Accessing study name / subgrapjs from another chart
View Count: 1206
| [2016-02-09 19:02:24] |
| User99735 - Posts: 234 |
Hi, When I try to access a study name / subgrapjs from another chart, the code is returning the study name from the current chart on which the study with the following code is applied - SCInputRef StudySubgraphReference = sc.Input[0]; StudySubgraphReference.Name = "Spread Sheet Chart And Study No"; StudySubgraphReference.SetChartStudyValues(1, 1); char msg[1000]; sprintf(msg, "Signal - %sd", sc.GetStudyNameFromChart(StudySubgraphReference.GetChartNumber(), StudySubgraphReference.GetStudyID())); sc.AddMessageToLog(msg, false); Please advice. Regards, Vivek |
| [2016-02-09 22:21:16] |
This means that the StudySubgraphReference Input is not set to the correct chart number.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-09 22:21:29
| [2016-02-09 22:25:14] |
Hi, There were two charts open #1 and #2, and the test study was running in #2 and the target study on #1. In the setting window of test study in #2, when #1 was entered in chart no, the correct study names and number appeared in the second dropdown. Please test at your end and revert. Regards Vivek |
| [2016-02-09 22:32:37] |
We ran a test now and confirmed there is nothing wrong. There must be something you are misunderstanding or doing incorrectly. Refer to this study function here which uses that function: /ACS_Source/Studies6.cpp >> scsf_DifferenceBar In Sierra Chart this is called Difference (Bar). Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-09 22:44:20] |
Hi, This example does not use StudySubgraphReference, do you have any example of same? Regards Vivek |
| [2016-02-09 23:13:37] |
The study function we referenced does access the first study graph with ID 0 which is the underlying the price graph of the chart. Refer to this study function instead: /ACS_Source/Studies8.cpp >> scsf_StudyOverlayOHLC Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-09 23:14:23
| [2016-02-09 23:14:56] |
We made a slight mistake in the prior post and corrected it. This is the study function you need to look at: /ACS_Source/Studies8.cpp >> scsf_StudyOverlayOHLC Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-09 23:15:10
| [2016-02-10 17:41:03] |
Ok, last query, will / does this work for spreadsheet also? Regards Vivek |
| [2016-02-10 17:52:10] |
We do not understand the question.
| [2016-02-10 17:54:56] |
Query was, that instead of an ACSIL study, if a spreadsheet study is attached to a chart, can the column data of the spreadsheet be accessed from another chart using the sample code in scsf_StudyOverlayOHLC. Still not working for me. Regards Vivek |
| [2016-02-10 18:16:27] |
The answer is yes. Here is the documentation for the study: https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s149 As a programmer, you should not have any trouble whatsoever using a study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-10 18:16:39
