Date/Time: Sun, 20 Sep 2026 11:42:48 +0000
Historical Data after update
View Count: 1028
[2016-02-09 18:11:12]
User76267 - Posts: 2
Hello, I've just updated SC to version 1366 (New Spreadsheet), before this update I had charts with ES(2) and TICK-NYSE(1) for 400 days in 5 minute charts. After the update I can not change the date range in each chart, respectively I can change the amount of days, but it doesn't work, I can see only range from today to cca beginning of January (2016-02-09 to 2016-01-07).
I tried Symbol update, Data service is correct (to SC All services). How should I proceed?
Thank you.
[2016-02-09 18:26:57]
We are looking into this problem now.
What you need to do for now is perform a Full Reset of the Symbol Settings as explained here:
https://www.sierrachart.com/index.php?page=doc/doc_GlobalSymbolSettings.php#FullResetSymbolSettingsSteps
After that is done reload the chart with Chart >> Reload and Recalculate.
[2016-02-09 21:23:28]
Thank you very much, it seems to work now.
