Date/Time: Mon, 28 Oct 2024 08:57:46 +0000
Massive lag on ES futures
View Count: 926
[2016-02-09 14:44:29] |
User52989 - Posts: 42 |
Sierra using Infinity/TransAct having massive lag of ~30 seconds today, which is several points delay. Any solutions?
[2016-02-09 18:31:34] |
Refer to help topic 4: Http://www.sierrachart.com/index.php?page=doc/helpdetails4.html There are different connection modes that can be used with TransAct. You can use UDP. If you right-click on the TransAct icon in the Windows taskbar system tray, you can change the mode from there. After doing this you will need to reconnect to the data feed: https://www.sierrachart.com/index.php?page=doc/doc_FileMenu.html#ProcedureToReconnect You may also want to consider using the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-09 18:32:14
