Date/Time: Mon, 28 Oct 2024 08:57:47 +0000
bars not painting
View Count: 951
[2016-02-09 06:33:56] |
User21339 - Posts: 61 |
Sometimes bars dont paint but i see price isnt where the last bar is. Ive tried edit>delete all data and download and reload charts but still the bars dont paint. Ive had issues where price bars are skewed and a delete and download works for that. but this missing bars is most annoying. any suggestions what i can try? |
[2016-02-09 07:20:15] |
Sounds like a problem with Session Times. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html#h7.3 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
