Date/Time: Mon, 28 Oct 2024 08:57:47 +0000
Volume by Price Default Settings
View Count: 647
[2016-02-09 02:21:01] |
sigmadict - Posts: 95 |
Hello, Is it possible to change the default Settings of the Draw Volume by Price Tool ? I would love not to have to change the properties every time I draw one, if I draw multiple ones, cause there's a lot of Settings to adjust everytime. Thanks Regards |
[2016-02-09 04:26:44] |
Yes. This is documented here: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DrawVolumeProfile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-09 08:55:21] |
We did not give a direct link to the specific documentation relevant to this. Here it is: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#DTConfigDrawVolumeProfileTool We also updated it to make it more clear. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
