Date/Time: Mon, 28 Oct 2024 08:57:46 +0000
GTC Order
View Count: 1425
[2016-02-08 09:19:40] |
User680060 - Posts: 7 |
Hello, Can You help me with one issue please? I want to use "Goog till Cancled" order, but if I stay in market over night, order (stop loss, profit target) will be cancle. What kind of order have to I use to stay in market with my atached orders over night? Thank You! best regards, JP. |
[2016-02-08 23:53:03] |
Refer to the documentation here about this: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#TimeInForce You need to set the Time in Force for the Attached Orders to also be Good till Canceled. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-09 14:19:11] |
I am sure I set this rightly. Nonetheless, order (SL, PT) is canceled at midnight. Every time.
ukazka.png / V - Attached On 2016-02-09 14:18:43 UTC - Size: 15.71 KB - 340 views |
[2016-02-09 18:34:23] |
Did you look at the screenshot in this section here showing the Time in Force setting for Attached Orders?: https://www.sierrachart.com/index.php?page=doc/doc_AttachedOrders.html#TimeInForce Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
