Date/Time: Thu, 24 Sep 2026 02:20:34 +0000
Forex - British Pound Feed
View Count: 1092
| [2016-02-08 07:22:48] |
| User888888 - Posts: 7 |
Hi, Am not getting a feed for British Pound, tried updating charts mutiple times, still no fix thank you |
| [2016-02-08 07:34:25] |
Futures or spot forex? What is the symbol of the chart? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-08 07:40:16] |
The Easy Screen data feed is giving an error for the 6B futures. We will have to check with them about this.
| [2016-02-08 07:43:52] |
Futures Symbol: CGCF:6B |
| [2016-02-08 08:18:09] |
Easy Screen has been contacted about this.
| [2016-02-09 07:11:56] |
Hello, The issue still has not been resolved |
| [2016-02-09 07:18:36] |
Yes we know. We will follow up with Easy Screen about this again. We did provide them the information yesterday but got no response after. We are following up again now.
| [2016-02-09 07:23:54] |
Okay Thank you
| [2016-02-09 10:38:59] |
Still no answer on this yet. We provided them detailed information about the request and the rejection for the 6B. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
