Date/Time: Sat, 28 Dec 2024 09:11:16 +0000
Offset.
View Count: 720
[2016-02-07 20:42:43] |
User700956 - Posts: 18 |
Hello. I would like to know how to apply a one tick offset. This can prevent being not filled on order entry. Thank you RC Johnsen
[2016-02-10 05:52:11] |
There are Trading Keyboard Commands that can be used to buy and sell using a 1 tick offset. Refer to: http://www.sierrachart.com/index.php?page=doc/doc_TradeWindow.html#KeyboardShortcuts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
