Date/Time: Wed, 09 Sep 2026 13:21:23 +0000
Control Bar Button
View Count: 1436
[2016-02-07 13:23:40]
User53601 - Posts: 107
During Intraday trading, most of the trading time I have set up the Chart Values/Crosshair button on the Control Bar.
From time to time I use some of the drawing tool and put it on the chart, for example a horizontal line.
After doing it, putting the horizontal line on the chart, I have to click back on the Chart Values/Crosshair button,
to stay in the mode of Crosshair.
Question:
Is there a way to stay in the current mode of Crosshair, having ocassionally clicking on the other button?
Saying otherway, is there possibility to configure some of the custom buttons such a way, that after onetime using of that other button, the mode will set back to previous button.
thank you
[2016-02-07 18:26:55]
There are two different ways of doing this. Refer to the documentation here:
Chart Drawing Tools: Using a Tool One Time, and Switching to the Default Tool
You can set an option to always have the Chart Values tool enabled with other Drawing Tools:
https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ChartValuesToolSettings
[2016-02-07 18:45:32]
that is it
thank you
