Date/Time: Thu, 19 Sep 2024 21:36:52 +0000
cant see my account number and account totals
View Count: 1805
[2013-06-28 08:57:10] |
User20108 - Posts: 32 |
Hi I can trad properly but cannot see my account number or the account totals so i am unable to monitor my trading please advice |
[2013-06-28 09:34:47] |
Can you please let us know what trading service you are using? What is Global Settings >> Data/Trade Service Settings >> Service set to? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-06-28 09:52:55] |
Live trading lmax live server |
[2013-06-28 10:16:55] |
In the next release, coming out in a day or 2, your username will be used as the account number when using LMAX trading. There is no account number thatt we have access to over the FIX connection. Since LMAX does not provide Account Balance or Position data over FIX, this is not accessible within Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
