Date/Time: Sat, 28 Dec 2024 08:59:37 +0000
Volume by price in the way of most current candle bars.
View Count: 887
[2016-02-06 18:07:49] |
User48557 - Posts: 138 |
AS you can see in the image, The volume by price profile is underneath the candle bars. Is there a way so the volume by price indicator (for the current time,not including yesterdays price action) can be all the way to the right of my screen so i can clearly see the candle bars. In the second image is a example of how i would like the profile to sit. These are the standard settings. With the standard settings i am allowed to use the ''lock fill space tab'' . The problem with the standard settings is i cannot see the prior days price action profiles. |
current.PNG / V - Attached On 2016-02-06 18:02:15 UTC - Size: 34.12 KB - 321 views how i want.PNG / V - Attached On 2016-02-06 18:05:36 UTC - Size: 41.57 KB - 331 views |
[2016-02-09 10:58:02] |
This is still pending review.
[2016-02-10 04:41:38] |
We have now had a chance to review this and what you want to accomplish is documented here: https://www.sierrachart.com/index.php?page=doc/doc_VolumeByPrice.php#RightAligningVolProfilesWithSpaceOnRight Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
