Date/Time: Fri, 11 Sep 2026 07:21:19 +0000
User Email
View Count: 1146
[2016-02-06 01:51:05]
Sierra Chart - Max - Posts: 5962
Hi guys,
There's still something strange with the Daily Change value in DAX Cash (using
TeleTrader feed). I'm using SierraCharts 1355. Don't know if this is "yours" or
"theirs"
I think the Daily Change should not be negative while the price is above where
it closed yesterday:
And this was the value a few seconds after opening (once the 1st bar appeared) -
I think the number was not right from the start :
Sierra Chart Support
imageghaijhig.png / V - Attached On 2016-02-06 01:49:51 UTC - Size: 13.3 KB - 379 views
imagejgjeeiib.png / V - Attached On 2016-02-06 01:49:56 UTC - Size: 13.68 KB - 451 views
[2016-02-09 10:42:58]
This was the response from TeleTrader in regards to this:
I think it makes little sense to use the %Change of the settlement price for the Cash DAX, as is this not a future where the usage of the %Change compared to the settlement price is more common.
German Exchange says about the Settlement price for Indices:
(Refer to attachment)
So the Settlement price seems to be updated between 13:00 and 13:02 each day.
I assume the %Change from the Settlement price goes to zero until the next price comes in, which would be as expected.
Here is the documentation about how the Daily Change is calculated:
Working With Charts: Chart Header Field Descriptions
If you have further questions, please use the Support Board only.
Date Time Of Last Edit: 2016-02-09 10:43:32
imageimage001.png / V - Attached On 2016-02-09 02:19:18 UTC - Size: 19.2 KB - 344 views
