Date/Time: Sat, 03 Oct 2026 06:38:51 +0000
new bars not drawing
View Count: 1381
| [2016-02-05 14:31:01] |
| jivetrader - Posts: 410 |
new bars not drawing in real time. DOM graph on chart updates, but price bars do not update. this is happening a lot lately and is obviously unacceptable for live trading.
| [2016-02-05 14:32:45] |
Reload and Recalc does not work. this is ridiculous! PLEASE ADVISE IMMEDIATELY
| [2016-02-05 14:55:01] |
i have been through all the help topics on this and nothing applies. bars are not drawing but the charts are set up properly, and the DOM is flashing/receiving new data just fine. HELP
| [2016-02-05 15:19:51] |
resolved. no idea what fixed it.
| [2016-02-05 16:44:29] |
this problem has recurred. it is intermittent. i have no idea what is causing this but it is business-stopping and i need a resolve ASAP.
| [2016-02-05 16:46:49] |
i am extremely upset about this!! this is unacceptable !
| [2016-02-05 18:57:34] |
We see you are using: GAIN Capital (OEC Trader) FIX
Refer to: https://www.sierrachart.com/index.php?page=doc/GAINCapitalOECTrader.php#SymbolLimit And refer to: http://www.sierrachart.com/index.php?page=doc/helpdetails3.html For a more reliable data feed, use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-05 19:59:55] |
again, the DOM is flashing/receiving new data just fine so the first two bullets do not apply ? there are only 3 charts in this chartbook, two with about 175 studies each. all use the same symbol, 6EHS. when i open a new chartbook with one simple chart of the same symbol (with the main dysfunctional one still open in the background), this chart updates just fine. switching back to the others, they do not update. disconnecting & reconnecting the feed does not help by itself. closing the program and reopening SOMETIMES helps, sometimes not. |
| [2016-02-05 20:41:05] |
The documentation says: When you have gone over the symbol limit, you will still see the price box on the right side of the chart move up and down, but the chart bars will not update.
On the Status Bar on the control bar after ST, what is the number? when i open a new chartbook with one simple chart of the same symbol (with the main dysfunctional one still open in the background), this chart updates just fine. switching back to the others, they do not update. Therefore, when you notice this problem remove all of the studies from the chart. See if the chart bars then update. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-05 20:42:04
| [2016-02-05 21:10:22] |
ST: 2 ok, i will start troubleshooting through the 175 studies. |
| [2016-02-05 21:30:08] |
OK there must be something unusual going on here. We do not know why studies would cause a problem, but we do not know exactly what you are seeing and what studies you are using.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-05 21:30:43
| [2026-03-24 05:42:45] |
| User111917 - Posts: 2 |
I am experiencing the same issue. I observed this issue for the first time while looking at NVDA charts like 1 hour before Market Close on Mar 23. I noticed first after enabling Numbers Bars Calculated Values 2 study. And since equities market has closed, I have been trying to resolve the issue by looking at the delayed futures data feed. I have tried on separate charts, some without studies, even going so far as to create a second installation to open a new instance. Same issue. The number after the ST in the control bar is 10. I have read multiple forum posts and help guides to rectify this issue with no success. Please assist with pointers. Thanks |
| [2026-03-24 06:27:44] |
| Sierra_Chart Engineering - Posts: 25040 |
Refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
