Date/Time: Sun, 27 Sep 2026 02:19:55 +0000
Sound Alerts
View Count: 979
| [2016-02-04 23:58:10] |
| User22243 - Posts: 2 |
How do I get wav files that I can download from the internet assigned to the Sierra Charts sound Alerts 1, 2 3 etc. Thanks, Tom Ramirez |
| [2016-02-05 03:43:15] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_GeneralSettings.html#AlertSoundSettings These files need to be put into the /AlertSounds subfolder in the folder that Sierra Chart is installed to on your system. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
