Date/Time: Sat, 28 Nov 2026 22:01:46 +0000
is there an exchange spread chart function in SC
View Count: 1365
| [2016-02-04 22:08:41] |
| Adam - Posts: 141 |
I knew this one on the roadmap and i wondered if this is now released? looks for simple front month - the 6th month spread for CME Energy products Adam |
| [2016-02-05 03:41:32] |
Yes. Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#CMEExchangeTradedSpreads Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-09 14:26:39] |
| Adam - Posts: 141 |
I use DTN IQFeed, how would it work for use with them?
| [2016-02-09 14:27:17] |
| Adam - Posts: 141 |
i just want to see the Front month - the second month in a candle format.
| [2016-02-09 18:56:07] |
Therefore, you need to use the proper DTN IQ Feed spread symbols. Refer to: DTN IQ Feed Data Service: Symbols Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
