Date/Time: Fri, 10 Jan 2025 09:54:14 +0000
Add Company Name to Chart
View Count: 1195
[2016-02-04 20:43:04] |
User623839 - Posts: 108 |
How can I add the COMPANY NAME to the top of my chart and How can I get rid some of the other text at the top of the chart..
Screen Shot 02-04-16 at 02.38 PM.PNG / V - Attached On 2016-02-04 20:39:50 UTC - Size: 5.31 KB - 297 views |
[2016-02-05 04:13:05] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TitleBarName https://www.sierrachart.com/index.php?page=doc/doc_WorkingWithCharts.html#RegionDataLine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-12 19:54:30] |
Can you tell me specifically "how to add the company name?" thank you |
[2016-02-12 20:15:59] |
You can use the Title Bar Name setting in Chart >> Chart Settings to set a name on the main title bar of Sierra Chart: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TitleBarName This name can be a company name. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-18 03:31:22] |
I want it to populate on the chart as I click through my watchlist. I cant "set a name" as this should populate automatically. I trade stocks and there are hundreds of them that I scan through. I tend to think that Sierras mindset is too futures/forex oriented sometimes... |
[2016-02-18 03:33:38] |
The name populates on the watchlist so we know that you already have the data. Just need to make that field available on the chart header
Screen Shot 02-17-16 at 09.32 PM.PNG / V - Attached On 2016-02-18 03:33:32 UTC - Size: 10.29 KB - 293 views |
[2016-02-18 04:06:09] |
You should see it now on the title bar of the chart. Do you? So you want it on the Region Data Line of the chart?
[2016-02-18 13:36:51] |
I don't use title bars because they are a waste of space....However, if this is the only solution I can make it work
[2016-02-18 16:46:30] |
OK we understand now. We will add the Description as a field which can be added to the Chart Header. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-19 03:43:03] |
sweet. thank you
[2016-02-21 00:43:35] |
When will this happen?
Screen Shot 02-20-16 at 06.43 PM.PNG / V - Attached On 2016-02-21 00:43:30 UTC - Size: 6.9 KB - 270 views |
[2016-02-21 00:51:59] |
The Description field has been added to Global Settings >> Customize Chart Header but this has not yet been released. We expect a new release in about three days. We just need to finish with some other development first. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-21 01:01:58] |
Nice work. Thanks guys:)
[2016-02-28 16:18:00] |
Still waiting on this???
[2016-02-29 14:47:22] |
Was this in the latest download?
[2016-02-29 17:31:22] |
Yes, this is in the current version. Follow the instructions here to update: https://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate Follow the instructions here to add the field: https://www.sierrachart.com/index.php?page=doc/doc_GlobalSettingsMenu.html#CustomizeChartHeader Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-29 21:54:42] |
Disregard Its working now thanks Date Time Of Last Edit: 2016-02-29 21:56:10
[2016-09-07 10:07:28] |
User37537 - Posts: 78 |
Hi support, did this break? I added 'Description' to Selected header Fields under Global Settings >> Customize Chart Header but I do not see the company name for equities. Also the 'Name' column on my quoteboard is blank for all tickers. I just upgraded to version 1460 and got the same result. I'm connected to "SC Data - All Services". I haven't paid attention to company name before so I don't know if it was ever working for me. Do I need to enable something? Do I need to subscribe to a real time data feed or be connected to my broker for this to work? Thanks! |
[2016-09-07 10:54:36] |
In the case of stocks, you need to use the Sierra Chart Exchange Data Feed for this: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
