Date/Time: Fri, 27 Sep 2024 03:50:09 +0000
Bar numbering studies
View Count: 705
[2016-02-04 19:22:53] |
User727245 - Posts: 29 |
1. Can you use 'bar numbering' studies to number ONLY the day session part on full session chart? 2. Can I control the time range of when the bar numbering starts and end? |
[2016-02-04 20:25:27] |
Neither of these are supported with the Bar Numbering study.
