Date/Time: Fri, 27 Sep 2024 03:45:30 +0000
Sierra chart data feed instead of Interactive Brokers data feed
View Count: 1651
[2016-02-04 18:27:44] |
User805092 - Posts: 17 |
Hello, I have a problem to get to my charts data from SC data feed. Everything should be activated and subscribed but if I set IB for trading,I get some data, but those data are from IB, not from Sierra. I cannot see [M] indicator as described and also chart DOM has just the nearest one bid and ask volume - data from IB. I cant get to point, I would have Dow Jones Industries futures YM-201603-ECBOT from Sierra data feed. Could you please describe step by step how to get it? I need to be sure I have tick data, not compressed from IB, because I trade volume bars. Thank you in advance for help. |
SC datafeed.JPG / V - Attached On 2016-02-04 18:25:52 UTC - Size: 297.54 KB - 407 views |
[2016-02-04 18:43:47] |
You need to connect to your Live Interactive Brokers account. You are not: Interactive Brokers | Connected to Demo or Simulated account. | 2016-02-04 12:32:16 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
