Date/Time: Mon, 05 Oct 2026 18:01:18 +0000
Custom Study Authorized Users Issue
View Count: 1335
[2016-02-04 18:17:20]
molandes1 - Posts: 8
Hello, I have a set of custom studies that I am going to sell on my website. I am confused on where the sc.IsUserAllowedForSCDLLName code goes inside of my study code. I tried to go by the example and when I try to add the compiled study to my chart it gives me the message that I am not authorized to use the study but it still plots it onto the chart. So this leads me to believe that I am doing something wrong. Please advise. Thanks and I look forward to hearing from you!
Once I get these issues worked out I will need to have the dll added to your database so that I can add users as they purchase. Thanks
[2016-02-04 18:55:27]
You need to use this just after the sc.SetDefaults code block:
if (!sc.IsUserAllowedForSCDLLName)
return;
So make sure there is a return.
Date Time Of Last Edit: 2016-02-04 18:55:51
