Date/Time: Fri, 18 Sep 2026 04:52:45 +0000
How to set 'twconfig' without quantity?
View Count: 1078
[2016-02-04 16:56:23]
jagoankita - Posts: 24
I use 'twconfig' for my chart trading; one strategy (twconfig file) applied to many stocks and also one stock use several kind on twconfig strategies. In this case I want my 'twconfig' files do not include guantity in it. I want the quantity that I already set on every chart won't change when switching between 'twconfig' files. Please let me know how to set the twconfig without quantity. Thank you.
[2016-02-04 18:39:57]
This is not supported. The quantity is saved in Trade Window configurations.
[2016-02-04 19:09:52]
In my case, one strategy for many stocks and one stock uses many strategies, those all are matrix that create hundreds of twconfig files. It will be very complicated setup. Hopefully, my suggestion, you can add "quantity=0" or just leave it blank to use quantity from the chart? With this setting, a trader like me can just prepare 5 twconfig files instead of several hundreds files that potentially create a lot of mistakes. Thank you.
[2016-02-05 09:03:51]
OK we will see about how to solve this. But it is not something we can do very quickly. Please allow about one month.
