Date/Time: Fri, 25 Sep 2026 05:30:44 +0000
How to get the highest and lowest closing price over the past x periods
View Count: 1244
[2016-02-04 01:23:44]
User972044 - Posts: 154
Hi there,
Just what the title says. I would like to find the highest and the lowest of closing prices over the last X periods and I can't find out how anywhere in the documentations.
Thank you for your help in advance.
[2016-02-04 05:21:00]
Use this chart Study:
https://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s54
Studies are added through Analysis >> Studies.
[2016-02-04 05:32:34]
Thanks for the answer but I was asking how do I get the highest and lowest of Close price over the last X bars or X period in a STUDY FUNCTION. I can't find that in the documentation.
Thank you in advance for your help.
[2016-02-04 05:54:46]
So you mean using ACSIL?
[2016-02-04 15:51:51]
Yes.
[2016-02-04 17:29:12]
Sierra Chart - Max - Posts: 5971
Refer to the following functions:
http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetHighest
http://www.sierrachart.com/index.php?page=doc/doc_ACSIL_Members_Functions.html#scGetLowest
Sierra Chart Support
