Date/Time: Sat, 28 Dec 2024 23:54:18 +0000
no data feed.
View Count: 639
[2016-02-03 19:28:53] |
User949842 - Posts: 1 |
hi support, In your sc data ( all service) , there is no crude oil march 2016. For some reason, i dont get live intraday data. The upper left side is green and says df:6 and st:2.. In my chartbook, i have CLH16 with some data but it not live. I wanted to test and feel the software in live interday data. Teem t_m_fong@yahoo.com |
[2016-02-03 19:31:28] |
Refer to this page here: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php It always surprises us how users expect to get real-time futures data so easily. You should be aware that this is tightly controlled by exchanges. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
