Date/Time: Mon, 16 Sep 2024 19:35:27 +0000
Tick Chart
View Count: 622
[2016-02-03 16:28:22] |
User756575 - Posts: 5 |
Hello, If I would have a chart with a candlestick or bar every 100 tick shall I select "Number Of Trades Per Bar" and put 100 in CS? Thanks for your answer. |
[2016-02-03 18:13:45] |
Yes this is correct. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
