Date/Time: Mon, 16 Sep 2024 19:19:50 +0000
Minute bar data
View Count: 588
[2016-02-03 14:40:51] |
User970233 - Posts: 3 |
Good Morning, I am able to obtain historical daily bar data with no problem. However, when I request historical minute bar data there is no response from the system. Is there a special procedure needed to obtain historical minute bar data in equities? |
[2016-02-03 18:01:38] |
After opening the Intraday chart, provide a copy of the Message Log by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
