Date/Time: Mon, 16 Sep 2024 19:21:59 +0000
Connection problems
View Count: 1242
[2016-02-03 13:09:25] |
User95457 - Posts: 19 |
Software version: 1252 | 2016-02-03 07:06:13 Uses Old Spreadsheets | 2016-02-03 07:06:13 Usage end date: 2016-02-14 | 2016-02-03 07:06:13 Enabled for: Advanced Features. | 2016-02-03 07:06:13 Enabled for: Sierra Chart Historical Data Service. | 2016-02-03 07:06:13 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-02-03 07:06:13 Active service: Rithmic Trading | 2016-02-03 07:06:13 Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-02-03 07:06:13 2016-02-03 14:06:13 Local computer clock time | 2016-02-03 07:06:13 2016-02-03 13:06:13 GMT time | 2016-02-03 07:06:13 2016-02-03 07:06:13 Time zone adjusted time | 2016-02-03 07:06:13 Time difference to server time: 2 seconds. | 2016-02-03 07:06:13 Program path: C:\SierraChart\ | 2016-02-03 07:06:13 Data Files path: C:\SierraChart\Data\ | 2016-02-03 07:06:13 OS Version Number: 6.1 | 2016-02-03 07:06:13 Locale Information: C | 2016-02-03 07:06:13 Checking for new symbol settings for rim | 2016-02-03 07:06:13 HTTP connection to www.sierrachart.com:80 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-02-03 07:06:13 HTTP connection to www.sierrachart.com:80 (1) | Connected. | 2016-02-03 07:06:13 Symbol settings are up-to-date for rim | 2016-02-03 07:06:13 Rithmic Trading | Port for executable: 49256 | 2016-02-03 07:06:18 Listening socket (1772), port 49256 | Closed. | 2016-02-03 07:06:18 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-02-03 07:06:18 HTTP connection to www.sierrachart.com:80 (1) | Closed. No error. | 2016-02-03 07:06:18 HTTP connection to www.sierrachart.com:80 (1) | Shutdown and closed. | 2016-02-03 07:06:18 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49256 | 2016-02-03 07:06:20 Socket (2) | Connected. | 2016-02-03 07:06:20 Rithmic Trading | Connected to server. | 2016-02-03 07:06:20 Rithmic Trading | Sending logon request message. | 2016-02-03 07:06:20 Rithmic Trading | Starting the connection process to data and trading service. | 2016-02-03 07:06:20 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-02-03 07:06:20 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2016-02-03 07:06:20 Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-02-03 07:06:23 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2016-02-03 07:06:23 Rithmic Trading | Server Name: DTC Bridge. | 2016-02-03 07:06:23 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2016-02-03 07:06:23 Rithmic Trading | Logon error from server | 2016-02-03 07:06:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:06:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:06:23 Socket (2) | Shutdown and closed. | 2016-02-03 07:06:23 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:06:23 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:06:23 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:06:25 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49256 | 2016-02-03 07:06:27 Socket (3) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:06:28 Socket (3) | Shutdown and closed. | 2016-02-03 07:06:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:06:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:06:28 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:06:28 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:06:28 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:06:30 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49256 | 2016-02-03 07:06:32 Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:06:33 Socket (4) | Shutdown and closed. | 2016-02-03 07:06:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:06:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:06:33 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:06:33 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:06:33 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:06:35 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49256 | 2016-02-03 07:06:37 Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:06:38 Socket (5) | Shutdown and closed. | 2016-02-03 07:06:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:06:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:06:38 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:06:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:06:38 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:06:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49256 | 2016-02-03 07:06:42 Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:06:43 Socket (6) | Shutdown and closed. | 2016-02-03 07:06:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:06:43 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:06:43 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:06:43 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:06:43 Rithmic Trading | Port for executable: 49272 | 2016-02-03 07:06:45 Listening socket (1780), port 49272 | Closed. | 2016-02-03 07:06:45 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-02-03 07:06:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49272 | 2016-02-03 07:06:48 Socket (7) | Connected. | 2016-02-03 07:06:48 Rithmic Trading | Connected to server. | 2016-02-03 07:06:48 Rithmic Trading | Sending logon request message. | 2016-02-03 07:06:48 Rithmic Trading | Starting the connection process to data and trading service. | 2016-02-03 07:06:48 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-02-03 07:06:48 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2016-02-03 07:06:48 Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-02-03 07:06:51 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2016-02-03 07:06:51 Rithmic Trading | Server Name: DTC Bridge. | 2016-02-03 07:06:51 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2016-02-03 07:06:51 Rithmic Trading | Logon error from server | 2016-02-03 07:06:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:06:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:06:51 Socket (7) | Shutdown and closed. | 2016-02-03 07:06:51 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:06:51 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:06:51 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:06:53 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49272 | 2016-02-03 07:06:55 Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:06:56 Socket (8) | Shutdown and closed. | 2016-02-03 07:06:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:06:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:06:56 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:06:56 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:06:56 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:06:58 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49272 | 2016-02-03 07:07:00 Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:07:01 Socket (9) | Shutdown and closed. | 2016-02-03 07:07:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:07:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:07:01 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:07:01 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:07:01 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:07:03 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49272 | 2016-02-03 07:07:05 Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:07:06 Socket (10) | Shutdown and closed. | 2016-02-03 07:07:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:07:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:07:06 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:07:06 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:07:06 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:07:08 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49272 | 2016-02-03 07:07:10 Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:07:11 Socket (11) | Shutdown and closed. | 2016-02-03 07:07:11 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:07:11 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:07:11 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:07:11 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:07:11 Rithmic Trading | Port for executable: 49309 | 2016-02-03 07:07:13 Listening socket (1256), port 49309 | Closed. | 2016-02-03 07:07:13 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-02-03 07:07:13 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49309 | 2016-02-03 07:07:15 Socket (12) | Connected. | 2016-02-03 07:07:15 Rithmic Trading | Connected to server. | 2016-02-03 07:07:15 Rithmic Trading | Sending logon request message. | 2016-02-03 07:07:15 Rithmic Trading | Starting the connection process to data and trading service. | 2016-02-03 07:07:15 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-02-03 07:07:15 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2016-02-03 07:07:15 Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-02-03 07:07:18 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2016-02-03 07:07:18 Rithmic Trading | Server Name: DTC Bridge. | 2016-02-03 07:07:18 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2016-02-03 07:07:18 Rithmic Trading | Logon error from server | 2016-02-03 07:07:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:07:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:07:18 Socket (12) | Shutdown and closed. | 2016-02-03 07:07:18 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:07:18 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:07:18 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:07:20 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49309 | 2016-02-03 07:07:22 Socket (13) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:07:23 Socket (13) | Shutdown and closed. | 2016-02-03 07:07:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:07:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:07:23 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:07:23 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:07:23 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:07:25 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49309 | 2016-02-03 07:07:27 Socket (14) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:07:28 Socket (14) | Shutdown and closed. | 2016-02-03 07:07:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:07:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:07:28 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:07:28 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:07:28 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:07:30 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49309 | 2016-02-03 07:07:32 Socket (15) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:07:33 Socket (15) | Shutdown and closed. | 2016-02-03 07:07:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:07:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:07:33 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:07:33 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:07:33 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:07:35 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49309 | 2016-02-03 07:07:37 Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:07:38 Socket (16) | Shutdown and closed. | 2016-02-03 07:07:38 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:07:38 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:07:38 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:07:38 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:07:38 Rithmic Trading | Port for executable: 49329 | 2016-02-03 07:07:41 Listening socket (1804), port 49329 | Closed. | 2016-02-03 07:07:41 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-02-03 07:07:41 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49329 | 2016-02-03 07:07:43 Socket (17) | Connected. | 2016-02-03 07:07:43 Rithmic Trading | Connected to server. | 2016-02-03 07:07:43 Rithmic Trading | Sending logon request message. | 2016-02-03 07:07:43 Rithmic Trading | Starting the connection process to data and trading service. | 2016-02-03 07:07:43 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-02-03 07:07:43 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2016-02-03 07:07:43 Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-02-03 07:07:46 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2016-02-03 07:07:46 Rithmic Trading | Server Name: DTC Bridge. | 2016-02-03 07:07:46 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2016-02-03 07:07:46 Rithmic Trading | Logon error from server | 2016-02-03 07:07:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:07:46 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:07:46 Socket (17) | Shutdown and closed. | 2016-02-03 07:07:46 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:07:46 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:07:46 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:07:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49329 | 2016-02-03 07:07:50 Socket (18) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:07:51 Socket (18) | Shutdown and closed. | 2016-02-03 07:07:51 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:07:51 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:07:51 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:07:51 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:07:51 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:07:53 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49329 | 2016-02-03 07:07:55 Socket (19) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:07:56 Socket (19) | Shutdown and closed. | 2016-02-03 07:07:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:07:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:07:56 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:07:56 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:07:56 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:07:58 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49329 | 2016-02-03 07:08:00 Socket (20) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:08:01 Socket (20) | Shutdown and closed. | 2016-02-03 07:08:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:08:01 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:08:01 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:08:01 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:08:01 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:08:03 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49329 | 2016-02-03 07:08:05 Socket (21) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:08:06 Socket (21) | Shutdown and closed. | 2016-02-03 07:08:06 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:08:06 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:08:06 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:08:06 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:08:06 Rithmic Trading | Port for executable: 49348 | 2016-02-03 07:08:08 Listening socket (1020), port 49348 | Closed. | 2016-02-03 07:08:08 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-02-03 07:08:08 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49348 | 2016-02-03 07:08:10 Socket (22) | Connected. | 2016-02-03 07:08:10 Rithmic Trading | Connected to server. | 2016-02-03 07:08:10 Rithmic Trading | Sending logon request message. | 2016-02-03 07:08:10 Rithmic Trading | Starting the connection process to data and trading service. | 2016-02-03 07:08:10 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-02-03 07:08:10 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2016-02-03 07:08:10 Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-02-03 07:08:13 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2016-02-03 07:08:13 Rithmic Trading | Server Name: DTC Bridge. | 2016-02-03 07:08:13 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2016-02-03 07:08:13 Rithmic Trading | Logon error from server | 2016-02-03 07:08:13 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:08:13 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:08:13 Socket (22) | Shutdown and closed. | 2016-02-03 07:08:13 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:08:13 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:08:13 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:08:15 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49348 | 2016-02-03 07:08:17 Socket (23) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:08:18 Socket (23) | Shutdown and closed. | 2016-02-03 07:08:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:08:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:08:18 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:08:18 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:08:18 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:08:20 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49348 | 2016-02-03 07:08:22 Socket (24) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:08:23 Socket (24) | Shutdown and closed. | 2016-02-03 07:08:23 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:08:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:08:23 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:08:23 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:08:23 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:08:25 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49348 | 2016-02-03 07:08:27 Socket (25) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:08:28 Socket (25) | Shutdown and closed. | 2016-02-03 07:08:28 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:08:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:08:28 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:08:28 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:08:28 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:08:30 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49348 | 2016-02-03 07:08:32 Socket (26) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:08:33 Socket (26) | Shutdown and closed. | 2016-02-03 07:08:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:08:33 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:08:33 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:08:33 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:08:33 Rithmic Trading | Port for executable: 49375 | 2016-02-03 07:08:35 Listening socket (1796), port 49375 | Closed. | 2016-02-03 07:08:35 Rithmic Trading | Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2016-02-03 07:08:35 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49375 | 2016-02-03 07:08:37 Socket (27) | Connected. | 2016-02-03 07:08:37 Rithmic Trading | Connected to server. | 2016-02-03 07:08:37 Rithmic Trading | Sending logon request message. | 2016-02-03 07:08:37 Rithmic Trading | Starting the connection process to data and trading service. | 2016-02-03 07:08:37 Rithmic Trading | Logging is enabled. Log file: C:\SierraChart\Rim\Rithmic.log | 2016-02-03 07:08:38 Rithmic Trading | Connecting to Rithmic Paper Trading server. | 2016-02-03 07:08:38 Rithmic Trading | Server Alert: Market Data Connection Opened | 2016-02-03 07:08:44 Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2016-02-03 07:08:44 Rithmic Trading | Server Name: DTC Bridge. | 2016-02-03 07:08:44 Rithmic Trading | Server protocol version: 5. Client protocol version: 5. There is a protocol match. | 2016-02-03 07:08:44 Rithmic Trading | Logon error from server | 2016-02-03 07:08:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:08:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:08:44 Socket (27) | Shutdown and closed. | 2016-02-03 07:08:44 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:08:44 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:08:44 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:08:46 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49375 | 2016-02-03 07:08:48 Socket (28) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:08:49 Socket (28) | Shutdown and closed. | 2016-02-03 07:08:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:08:49 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:08:49 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:08:49 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:08:49 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:08:51 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49375 | 2016-02-03 07:08:53 Socket (29) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:08:54 Socket (29) | Shutdown and closed. | 2016-02-03 07:08:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:08:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:08:54 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:08:54 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:08:54 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:08:56 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49375 | 2016-02-03 07:08:58 Socket (30) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:08:59 Socket (30) | Shutdown and closed. | 2016-02-03 07:08:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:08:59 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:08:59 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:08:59 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:08:59 Rithmic Trading | Bridge process is still running. | 2016-02-03 07:09:01 Rithmic Trading | Connecting to the server 127.0.0.1. Port 49375 | 2016-02-03 07:09:03 Socket (31) | Error received in OnConnect while connecting. Windows error code 10061: Impossibile stabilire la connessione. Rifiuto persistente del computer di destinazione. | 2016-02-03 07:09:04 Socket (31) | Shutdown and closed. | 2016-02-03 07:09:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-03 07:09:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-03 07:09:04 Rithmic Trading | Disconnected from the server. | 2016-02-03 07:09:04 Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-03 07:09:04 |
[2016-02-03 14:25:49] |
SC Developer - David - Posts: 660 |
Refer to: Rithmic Trading Platform Service: Permission Denied Resolution Procedure |
[2016-02-03 17:54:02] |
This is the relevant error message: Rithmic Trading | Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2016-02-03 07:08:44 Refer to the instructions here: Rithmic Trading Platform Service: Permission Denied Resolution Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
