Date/Time: Sat, 03 Oct 2026 06:54:18 +0000
left align profile with number bars
View Count: 1571
| [2016-02-03 03:14:08] |
| User20450 - Posts: 330 |
is there any way to align the left align profile so the first set of number bars does not sit right on top of profile and block it ? thanks
| [2016-02-03 03:40:59] |
Provide an image of the chart, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2016-02-03 13:34:45] |
i would use the right align but i use market depth , is there a way to align these so there not over lapping ?
| [2016-02-03 18:03:54] |
We do not see how this could be made any better. Other than using a separate chart for the Volume by Price study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2016-02-03 18:04:06
