Date/Time: Thu, 28 Nov 2024 00:47:38 +0000
Editing, trade activity log
View Count: 1237
[2016-02-03 02:42:56] |
User439550 - Posts: 12 |
Is there a way to edit or add entries in the trades section?, my computer crashed while holding an open position. my trade was taken care off by at the floor...my exit time for the trade says "unmatched fill" I want to edit that line so that my statistics go back to normal... thanks |
[2016-02-03 03:04:41] |
Yes you can do this. Refer to: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#MissingOrderFills Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-15 16:58:38] |
Boris Libman - Posts: 58 |
Along a similar topic, I was testing something in a sim strategy and generated several in/out trades that I don't want in the log (I use the log to analyze a test strategy). Is there a way to remove specific trades from log without clearing out all trades for the day (some of which I want to preserve). Thank you.
[2023-06-15 17:29:13] |
Select the line you want to delete and select "Edit >> Delete Trade Activity Entry".
