Date/Time: Thu, 24 Sep 2026 06:08:19 +0000
[User Discussion] - How to make stop order not move or cancel?
View Count: 1035
| [2016-02-03 01:49:09] |
| idcisosf - Posts: 34 |
Is there any ways which once order have been opened, then It can't be removed, until it got fill. For example: Let's say I have bracket orders with Trailing stop, If I long or short a symbol, which will create this bracket order, then I want to make the Trailing stop order can't be removed, cancel or changed, only the target limit order can be moving for adjustment by me till it got fill. So, I'd like to know how to do this. Thank, |
| [2016-02-03 01:52:44] |
This is not supported.
| [2016-02-05 00:58:43] |
Is there any ways which once order have been opened, then It can't be removed, until it got fill. For example: Let's say I have bracket orders with Trailing stop, If I long or short a symbol, which will create this bracket order, then I want to make the Trailing stop order can't be removed, cancel or changed, only the target limit order can be moving for adjustment by me till it got fill. So, I'd like to know how to do this. Can this to be done by programming? Thank, |
| [2016-02-05 01:21:27] |
There is no way in Sierra Chart to prevent this. The order can always be manually modified or canceled by the user.
