Date/Time: Mon, 16 Sep 2024 19:46:56 +0000
Daily Pivot Point Levels
View Count: 917
[2016-02-02 23:01:00] |
User550516 - Posts: 9 |
Can anyone help me with setting up the daily pivot points S1 and S2 and so on?
[2016-02-03 01:48:40] |
Infinite - Posts: 134 |
Pretty straight forward. In the first box of the daily pivot points try a 13 type of pivot point. It is fibonacci based PP's and u will see the prices turn on those lines. enable all the S and R levels u want. U will need to have a seperate daily chart set up that will be referenced from the Daily PP study on your chart, for it to work more accurately. |
[2016-02-04 09:27:19] |
Refer to the documentation here: https://www.sierrachart.com/index.php?page=doc/doc_PivotPoints.html#HidingDisplayingLevels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
