Date/Time: Sun, 29 Dec 2024 00:04:58 +0000
SC data feed and IB provider
View Count: 1142
[2016-02-02 17:33:10] |
User147025 - Posts: 6 |
I'm trying already couple day to connect to SC with data feed and i think i fallowed all step by step through instructions and i still have a problems to connect. here is the list: in data/trade service settings i enable allow support for SC data feed and like a service i have IB. on the other side in TWS i enable ActiveX and socket clients and i typed trust to 127.0.0.1 IPs when I go to connect it's still connecting and in message log is error 10061. What am i doing wrong, can you help me please? |
[2016-02-02 18:29:42] |
Follow through step number 22 here: Interactive Brokers Trading Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-02 18:58:19] |
I was calling with IB customer service and I set up all with their assistance. Now i fallowed your double check in SC, I turn off the Firewall and i still have the error 10061.
[2016-02-02 19:09:53] |
Provide a copy of the Message Log by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-02 19:21:28] |
Software version: 1352 | 2016-02-02 11:02:48 Uses New Spreadsheets | 2016-02-02 11:02:48 Usage end date: 2016-05-03 | 2016-02-02 11:02:48 Enabled for: Advanced Features. | 2016-02-02 11:02:48 Enabled for: Advanced Features 2. | 2016-02-02 11:02:48 Enabled for: Sierra Chart Historical Data Service. | 2016-02-02 11:02:48 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2016-02-02 11:02:48 Enabled for: INDEXES_DATA_BARCHART | 2016-02-02 11:02:48 Enabled for: CME (Trading Account Required) | 2016-02-02 11:02:48 Enabled for: CBOT (Trading Account Required) | 2016-02-02 11:02:48 Enabled for: COMEX (Trading Account Required) | 2016-02-02 11:02:48 Enabled for: NYMEX (Trading Account Required) | 2016-02-02 11:02:48 Received 1 data feed usernames. | 2016-02-02 11:02:48 Allow Support for Sierra Chart Data Feeds is enabled. | 2016-02-02 11:02:48 Current selected Data/Trading service: Interactive Brokers | 2016-02-02 11:02:48 Chart Update Interval: 200 | 2016-02-02 11:02:48 Time Zone: -08:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-02-02 11:02:48 2016-02-02 11:02:48 Local computer time | 2016-02-02 11:02:48 2016-02-02 19:02:48 Local computer time in UTC | 2016-02-02 11:02:48 2016-02-02 11:02:48 Local computer time in SC Time Zone | 2016-02-02 11:02:48 2016-02-02 19:02:47 Server time in UTC | 2016-02-02 11:02:48 Local computer UTC time and Server UTC time difference: 1 seconds. | 2016-02-02 11:02:48 Program path: C:\SierraChart\ | 2016-02-02 11:02:48 Data Files path: C:\SierraChart\Data\ | 2016-02-02 11:02:48 OS Version Number: 6.1 | 2016-02-02 11:02:48 Locale Information: C | 2016-02-02 11:02:48 Checking for new symbol settings for ib | 2016-02-02 11:02:48 HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-02-02 11:02:48 HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-02-02 11:02:48 HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-02-02 11:02:48 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-02-02 11:02:49 Symbol settings are up-to-date for ib | 2016-02-02 11:02:49 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:02:53 HTTPS connection to www.sierrachart.com:443 (3) | SSL connection closed by remote side. | 2016-02-02 11:02:54 HTTPS connection to www.sierrachart.com:443 (3) | SSL object has been freed. SSL state is now disconnected. | 2016-02-02 11:02:54 HTTPS connection to www.sierrachart.com:443 (3) | Shutdown and closed. | 2016-02-02 11:02:54 Socket (4) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:02:54 Socket (4) | Shutdown and closed. | 2016-02-02 11:02:54 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:02:54 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:02:54 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:02:54 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:02:54 Interactive Brokers | Disconnected. | 2016-02-02 11:02:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:02:54 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:02:57 Socket (5) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:02:58 Socket (5) | Shutdown and closed. | 2016-02-02 11:02:58 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:02:58 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:02:58 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:02:58 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:02:58 Interactive Brokers | Disconnected. | 2016-02-02 11:02:58 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:02:58 File >> Disconnect selected. | 2016-02-02 11:02:59 Interactive Brokers | Disconnected. | 2016-02-02 11:02:59 Current selected Data/Trading service: Interactive Brokers | 2016-02-02 11:03:10 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:03:15 Socket (6) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:03:16 Socket (6) | Shutdown and closed. | 2016-02-02 11:03:16 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:03:16 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:03:16 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:03:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:03:16 Interactive Brokers | Disconnected. | 2016-02-02 11:03:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:03:16 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:03:19 Socket (7) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:03:20 Socket (7) | Shutdown and closed. | 2016-02-02 11:03:20 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:03:20 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:03:20 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:03:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:03:20 Interactive Brokers | Disconnected. | 2016-02-02 11:03:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:03:20 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:03:23 Socket (8) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:03:24 Socket (8) | Shutdown and closed. | 2016-02-02 11:03:24 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:03:24 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:03:24 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:03:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:03:24 Interactive Brokers | Disconnected. | 2016-02-02 11:03:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:03:24 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:03:27 Socket (9) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:03:28 Socket (9) | Shutdown and closed. | 2016-02-02 11:03:28 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:03:28 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:03:28 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:03:28 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:03:28 Interactive Brokers | Disconnected. | 2016-02-02 11:03:28 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:03:28 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:03:31 Socket (10) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:03:32 Socket (10) | Shutdown and closed. | 2016-02-02 11:03:32 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:03:32 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:03:32 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:03:32 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:03:32 Interactive Brokers | Disconnected. | 2016-02-02 11:03:32 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:03:32 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:03:35 Socket (11) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:03:36 Socket (11) | Shutdown and closed. | 2016-02-02 11:03:36 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:03:36 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:03:36 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:03:36 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:03:36 Interactive Brokers | Disconnected. | 2016-02-02 11:03:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:03:36 File >> Disconnect selected. | 2016-02-02 11:03:37 Interactive Brokers | Disconnected. | 2016-02-02 11:03:37 Current selected Data/Trading service: Interactive Brokers | 2016-02-02 11:11:11 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:11:18 Socket (16) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:11:19 Socket (16) | Shutdown and closed. | 2016-02-02 11:11:19 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:11:19 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:11:19 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:11:19 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:11:19 Interactive Brokers | Disconnected. | 2016-02-02 11:11:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:11:19 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:11:22 Socket (17) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:11:23 Socket (17) | Shutdown and closed. | 2016-02-02 11:11:23 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:11:23 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:11:23 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:11:23 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:11:23 Interactive Brokers | Disconnected. | 2016-02-02 11:11:23 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:11:23 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:11:26 Socket (18) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:11:27 Socket (18) | Shutdown and closed. | 2016-02-02 11:11:27 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:11:27 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:11:27 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:11:27 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:11:27 Interactive Brokers | Disconnected. | 2016-02-02 11:11:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:11:27 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:11:30 Socket (19) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:11:31 Socket (19) | Shutdown and closed. | 2016-02-02 11:11:31 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:11:31 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:11:31 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:11:31 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:11:31 Interactive Brokers | Disconnected. | 2016-02-02 11:11:31 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:11:31 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:11:34 Socket (20) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:11:35 Socket (20) | Shutdown and closed. | 2016-02-02 11:11:35 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:11:35 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:11:35 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:11:35 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:11:35 Interactive Brokers | Disconnected. | 2016-02-02 11:11:35 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:11:35 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:11:38 Socket (21) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:11:39 Socket (21) | Shutdown and closed. | 2016-02-02 11:11:39 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:11:39 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:11:39 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:11:39 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:11:39 Interactive Brokers | Disconnected. | 2016-02-02 11:11:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:11:39 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:11:42 Socket (22) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:11:44 Socket (22) | Shutdown and closed. | 2016-02-02 11:11:44 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:11:44 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:11:44 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:11:44 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:11:44 Interactive Brokers | Disconnected. | 2016-02-02 11:11:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:11:44 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:11:47 Socket (23) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:11:48 Socket (23) | Shutdown and closed. | 2016-02-02 11:11:48 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:11:48 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:11:48 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:11:48 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:11:48 Interactive Brokers | Disconnected. | 2016-02-02 11:11:48 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:11:48 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:11:51 Socket (24) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:11:52 Socket (24) | Shutdown and closed. | 2016-02-02 11:11:52 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:11:52 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:11:52 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:11:52 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:11:52 Interactive Brokers | Disconnected. | 2016-02-02 11:11:52 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:11:52 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:11:55 Socket (25) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:11:56 Socket (25) | Shutdown and closed. | 2016-02-02 11:11:56 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:11:56 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:11:56 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:11:56 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:11:56 Interactive Brokers | Disconnected. | 2016-02-02 11:11:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:11:56 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:11:59 Socket (26) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:12:00 Socket (26) | Shutdown and closed. | 2016-02-02 11:12:00 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:12:00 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:12:00 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:12:00 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:12:00 Interactive Brokers | Disconnected. | 2016-02-02 11:12:00 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:12:00 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:12:03 Socket (27) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:12:04 Socket (27) | Shutdown and closed. | 2016-02-02 11:12:04 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:12:04 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:12:04 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:12:04 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:12:04 Interactive Brokers | Disconnected. | 2016-02-02 11:12:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:12:04 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:12:07 Socket (28) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:12:08 Socket (28) | Shutdown and closed. | 2016-02-02 11:12:08 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:12:08 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:12:08 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:12:08 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:12:08 Interactive Brokers | Disconnected. | 2016-02-02 11:12:08 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:12:08 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:12:11 Socket (29) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:12:12 Socket (29) | Shutdown and closed. | 2016-02-02 11:12:12 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:12:12 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:12:12 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:12:12 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:12:12 Interactive Brokers | Disconnected. | 2016-02-02 11:12:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:12:12 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:12:15 Socket (30) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:12:16 Socket (30) | Shutdown and closed. | 2016-02-02 11:12:16 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:12:16 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:12:16 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:12:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:12:16 Interactive Brokers | Disconnected. | 2016-02-02 11:12:16 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:12:16 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:12:19 Socket (31) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:12:20 Socket (31) | Shutdown and closed. | 2016-02-02 11:12:20 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:12:20 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:12:20 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:12:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:12:20 Interactive Brokers | Disconnected. | 2016-02-02 11:12:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:12:20 Interactive Brokers: Connecting to 127.0.0.1:7497 | 2016-02-02 11:12:23 Socket (32) | Error received in OnConnect while connecting. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2016-02-02 11:12:24 Socket (32) | Shutdown and closed. | 2016-02-02 11:12:24 Interactive Brokers | Failed to connect to the data and trade server. | 2016-02-02 11:12:24 * Note: Is the Interactive Brokers TWS software running and is it enabled for socket clients? | 2016-02-02 11:12:24 * Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 11:12:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 11:12:24 Interactive Brokers | Disconnected. | 2016-02-02 11:12:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 11:12:24 |
[2016-02-02 19:38:59] |
Are you running any firewall software on your computer other than the Windows firewall?
[2016-02-02 19:41:01] |
No
[2016-02-02 19:48:35] |
Can we give you a call to look into this using remote assistance?
[2016-02-02 19:52:20] |
yes that can be the best
Date Time Of Last Edit: 2016-02-02 22:30:59
