Date/Time: Sun, 29 Dec 2024 00:05:15 +0000
SC real time data feed and IB provider
View Count: 640
[2016-02-02 16:24:42] |
User147025 - Posts: 6 |
I fallowed your step by step instructions on how to set it up and it did not work. Can you please advise me on what to do next? The charts are static and not moving and it delayed by 10 minutes |
[2016-02-02 18:30:27] |
Refer to the response here: SC data feed and IB provider Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
