Date/Time: Sun, 29 Dec 2024 00:01:11 +0000
Problem loging into Barchart
View Count: 970
[2016-02-02 12:44:35]
User76803 - Posts: 2
Software version: 1362 | 2016-02-02 06:28:42
Uses New Spreadsheets | 2016-02-02 06:28:42
Usage end date: 2016-04-08 | 2016-02-02 06:28:42
Enabled for: Advanced Features. | 2016-02-02 06:28:42
Enabled for: Advanced Features 2. | 2016-02-02 06:28:42
Enabled for: Sierra Chart Historical Data Service. | 2016-02-02 06:28:42
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2016-02-02 06:28:42
Enabled for: INDEXES_DATA_BARCHART | 2016-02-02 06:28:42
Enabled for: U.S. Equities (NYSE, NASDAQ, AMEX, BATS) | 2016-02-02 06:28:42
Received 1 data feed usernames. | 2016-02-02 06:28:42
Allow Support for Sierra Chart Data Feeds is enabled. | 2016-02-02 06:28:42
Current selected Data/Trading service: Barchart | 2016-02-02 06:28:42
Chart Update Interval: 500 | 2016-02-02 06:28:42
Time Zone: -06:00:00 (CST-06CDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2016-02-02 06:28:42
2016-02-02 06:28:42 Local computer time | 2016-02-02 06:28:42
2016-02-02 12:28:42 Local computer time in UTC | 2016-02-02 06:28:42
2016-02-02 06:28:42 Local computer time in SC Time Zone | 2016-02-02 06:28:42
2016-02-02 12:28:41 Server time in UTC | 2016-02-02 06:28:42
Local computer UTC time and Server UTC time difference: 0 seconds. | 2016-02-02 06:28:42
Program path: C:\SierraChart\ | 2016-02-02 06:28:42
Data Files path: C:\SierraChart\Data\ | 2016-02-02 06:28:42
OS Version Number: 6.1 | 2016-02-02 06:28:42
Locale Information: C | 2016-02-02 06:28:42
Checking for new symbol settings for ddf | 2016-02-02 06:28:42
HTTPS connection to www.sierrachart.com:443 (0) | Resolved address sierrachart.com to IP 5.9.8.236 | 2016-02-02 06:28:42
HTTPS connection to www.sierrachart.com:443 (3) | Connected. | 2016-02-02 06:28:42
HTTPS connection to www.sierrachart.com:443 (3) | Starting TLS 1.2 connection. | 2016-02-02 06:28:42
HTTPS connection to www.sierrachart.com:443 (3) | SSL connection established. | 2016-02-02 06:28:42
Symbol settings are up-to-date for ddf | 2016-02-02 06:28:47
Barchart | Verifying status of username. | 2016-02-02 06:41:15
Barchart | Requesting user settings from http://www.ddfplus.com for 95489_1 | 2016-02-02 06:41:15
HTTP connection to www.ddfplus.com:80 (0) | Resolved address www.ddfplus.com to IP 8.18.161.212 | 2016-02-02 06:41:15
HTTP connection to www.ddfplus.com:80 (46) | Connected. | 2016-02-02 06:41:15
Barchart | User settings received. | 2016-02-02 06:41:15
Barchart | Authorized exchanges: AMEX,NYSE,NTDS,OTCBB,FUND,INDEX,AMEXBA,NYSEBA,NTDSBA,OTCBBBA | 2016-02-02 06:41:15
Barchart | Connecting to server qs02.aws.ddfplus.com:7500 | 2016-02-02 06:41:15
Socket (0) | Resolved address ec2-174-129-40-242.compute-1.amazonaws.com to IP 174.129.40.242 | 2016-02-02 06:41:15
Socket (47) | Connected. | 2016-02-02 06:41:15
Barchart | Waiting for initial message from server. | 2016-02-02 06:41:15
Barchart | Sending the LOGIN command. | 2016-02-02 06:41:15
Barchart | Sending the VERSION command. | 2016-02-02 06:41:15
Barchart | Negative info message: - Login Failed | 2016-02-02 06:41:15 *
Barchart | Connection error. | 2016-02-02 06:41:15 *
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2016-02-02 06:41:15
To prevent further connection attempts, select 'File >> Disconnect'. | 2016-02-02 06:41:15
Socket (47) | Closed. No error. | 2016-02-02 06:41:15
Socket (47) | Shutdown and closed. | 2016-02-02 06:41:15
Barchart | Reset socket. | 2016-02-02 06:41:15
Barchart | Disconnected. | 2016-02-02 06:41:15
Will reconnect to the server in 3.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2016-02-02 06:41:15
Date Time Of Last Edit: 2016-02-02 13:58:32
[2016-02-02 13:57:24]
We see you are using the Sierra Chart Exchange Data Feed:
Follow step 15 here to set the Service correctly:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#SetupInstructions
You cannot use the service named "Barchart". You most likely will be using "SC Data-All Services"
Date Time Of Last Edit: 2016-02-02 13:57:40
