Date/Time: Tue, 14 Jul 2026 05:37:56 +0000
NQ in different decimal format
View Count: 982
| [2016-02-02 11:07:17] |
| User58159 - Posts: 62 |
Dear Friends, yesterday I bought a new IB historical data and exchange fee and I have found on my trading windows different NQ index format that I see as usual. First, I thought that this is the step of IB to cover exchange fee on the way (they were transfered), but today I see the same. I try to change format to the normal one via chart settings, but no success. former format NQ 4249.50 wrong one NQ 42.4950 Please, advice. |
| [2016-02-02 13:50:01] |
Select Chart >> Chart Settings. Make sure "Auto Set from Data Feed" is unchecked. The setting is by the "Price Display Format" setting. And follow the instructions here to apply the Global Symbol Settings to the chart: Global Symbol Settings: Update/Apply Symbol Settings to Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
