Date/Time: Sun, 29 Dec 2024 00:10:12 +0000
Adjusting Chart Regions through Value Scale
View Count: 725
[2016-02-02 05:27:07] |
User296389 - Posts: 31 |
Hi, Previously was able to perform the adjustment of the chart regions through the value scale, however currently is not able to perform it ( The convenient way ). Kindly assist, appreciate and thanks. |
[2016-02-02 07:26:19] |
We tested this and we do not see a problem. Select Tools >> Pointer. When you hover over the dividing area between Chart Regions in the Values Scale, do you see a short horizontal line displayed? You should. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2016-02-03 01:43:03] |
thanks got it! Cheers |
