Date/Time: Fri, 11 Sep 2026 04:42:02 +0000
Sierra Chart Exchange Data Feed Users with Multiple Data Feed Connections
View Count: 1286
[2016-02-02 03:34:14]
On 2016-02-01, our Sierra Chart Exchange Data Feed users who have more than one real-time data connection, were being refused the additional connections beyond the first real-time connection.
This problem was resolved sometime before 3 PM US Eastern time.
This was due to a software update on Sunday where we corrected a problem where when a user is logged off for a certain reason after a successful logon, an unsuccessful logon response was being sent to the client.
This was not correct and it was changed to be a standard logoff response. However, this change also caused an unsuccessful logon to also use a logoff message rather than a logon response message with an error flag.
Anyway, this is a bit technical and to get to the point, this was causing a problem in Sierra Chart where it was not providing a usable username to log onto the data feed.
These two issues have been solved on both the client and server-side now. An incident like this cannot happen again.
We also have never had a situation like this occur previously. So trust that it will not happen again with the changes that have been made.
We will be giving each of the affected users, a short time extension for the difficulty today.
The changes have been released on the server now and also in Sierra Chart version 1364.
Date Time Of Last Edit: 2016-02-02 07:31:02
[2018-06-20 07:08:35]
User713273 - Posts: 409
Software version: 1767 32-bit | 2018-06-20 00:06:13
Usage end date: 2018-07-24 | 2018-06-20 00:06:13
Enabled for: Advanced Features. | 2018-06-20 00:06:13
Enabled for: Advanced Features 2. | 2018-06-20 00:06:13
Enabled for: Sierra Chart Historical Data Service. | 2018-06-20 00:06:13
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-06-20 00:06:13
Enabled for: INDEXES_DATA_BARCHART | 2018-06-20 00:06:13
Enabled for: U.S. Equities (NYSE, NASDAQ, AMEX, BATS) | 2018-06-20 00:06:13
Enabled for: BATS (NYSE, NASDAQ) | 2018-06-20 00:06:13
Received 3 data feed usernames. | 2018-06-20 00:06:13
Allow Support for Sierra Chart Data Feeds is enabled. | 2018-06-20 00:06:13
Current selected Data/Trading service: Interactive Brokers | 2018-06-20 00:06:13
Chart Update Interval: 1000 | 2018-06-20 00:06:13
Time Zone: -07:00:00 (PST-08PDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-06-20 00:06:13
2018-06-20 00:06:13 Local computer time | 2018-06-20 00:06:13
2018-06-20 07:06:13 Local computer time in UTC | 2018-06-20 00:06:13
2018-06-20 00:06:13 Local computer time in SC Time Zone | 2018-06-20 00:06:13
2018-06-20 07:02:14 Server time in UTC | 2018-06-20 00:06:13
Local computer UTC time and Server UTC time difference: 1 seconds. | 2018-06-20 00:06:13
Program path: C:\SierraChart2\ | 2018-06-20 00:06:13
Data Files path: C:\SierraChart2\Data\ | 2018-06-20 00:06:13
OS Version Number: 6.1 | 2018-06-20 00:06:13
Locale Setting: C | 2018-06-20 00:06:13
SC Data - All Services | Using username 2 | 2018-06-20 00:06:14
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:06:14
DTC Client socket (25) | Creating socket. | 2018-06-20 00:06:14
DTC Client socket (25) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:14
SC Data - All Services | Connected to server. | 2018-06-20 00:06:14
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:14
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:14
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:14
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:14
SC Data - All Services | Received logon response. | 2018-06-20 00:06:15
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:15
DTC Client socket (25) | Socket gracefully closed by remote side. | 2018-06-20 00:06:15
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:15
DTC Client socket (25) | Received socket Close event. | 2018-06-20 00:06:15
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:15
DTC Client socket (25) | Initiating close of socket by core. | 2018-06-20 00:06:15
DTC Client socket (25) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:15
DTC Client socket (25) | Closed. | 2018-06-20 00:06:15
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:15
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:15
SC Data - All Services | Using username 0 | 2018-06-20 00:06:17
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:06:17
DTC Client socket (26) | Creating socket. | 2018-06-20 00:06:17
DTC Client socket (26) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:06:17
SC Data - All Services | Connected to server. | 2018-06-20 00:06:17
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:17
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:17
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:17
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:17
SC Data - All Services | Received logon response. | 2018-06-20 00:06:17
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:17
DTC Client socket (26) | Socket gracefully closed by remote side. | 2018-06-20 00:06:17
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:17
DTC Client socket (26) | Received socket Close event. | 2018-06-20 00:06:17
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:17
DTC Client socket (26) | Initiating close of socket by core. | 2018-06-20 00:06:17
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:17
DTC Client socket (26) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:17
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:17
DTC Client socket (26) | Closed. | 2018-06-20 00:06:17
SC Data - All Services | Using username 0 | 2018-06-20 00:06:19
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:06:19
DTC Client socket (27) | Creating socket. | 2018-06-20 00:06:19
DTC Client socket (27) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:19
SC Data - All Services | Connected to server. | 2018-06-20 00:06:19
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:19
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:19
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:19
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:19
SC Data - All Services | Received logon response. | 2018-06-20 00:06:19
DTC Client socket (27) | Socket gracefully closed by remote side. | 2018-06-20 00:06:19
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:19
DTC Client socket (27) | Received socket Close event. | 2018-06-20 00:06:19
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:19
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:19
DTC Client socket (27) | Initiating close of socket by core. | 2018-06-20 00:06:19
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:19
DTC Client socket (27) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:19
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:19
DTC Client socket (27) | Closed. | 2018-06-20 00:06:19
SC Data - All Services | Using username 1 | 2018-06-20 00:06:21
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:06:21
DTC Client socket (28) | Creating socket. | 2018-06-20 00:06:21
DTC Client socket (28) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:06:21
SC Data - All Services | Connected to server. | 2018-06-20 00:06:21
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:21
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:21
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:21
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:21
DTC Client socket (28) | Received socket Close event. | 2018-06-20 00:06:21
DTC Client socket (28) | Socket gracefully closed by remote side. | 2018-06-20 00:06:21
DTC Client socket (28) | Initiating close of socket by core. | 2018-06-20 00:06:21
DTC Client socket (28) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:21
DTC Client socket (28) | Closed. | 2018-06-20 00:06:21
SC Data - All Services | Received logon response. | 2018-06-20 00:06:21
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:21
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:21
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:21
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:21
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:21
SC Data - All Services | Using username 1 | 2018-06-20 00:06:23
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:06:23
DTC Client socket (29) | Creating socket. | 2018-06-20 00:06:23
DTC Client socket (29) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:23
SC Data - All Services | Connected to server. | 2018-06-20 00:06:24
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:24
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:24
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:24
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:24
SC Data - All Services | Received logon response. | 2018-06-20 00:06:24
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:24
DTC Client socket (29) | Socket gracefully closed by remote side. | 2018-06-20 00:06:24
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:24
DTC Client socket (29) | Received socket Close event. | 2018-06-20 00:06:24
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:24
DTC Client socket (29) | Initiating close of socket by core. | 2018-06-20 00:06:24
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:24
DTC Client socket (29) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:24
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:24
DTC Client socket (29) | Closed. | 2018-06-20 00:06:24
SC Data - All Services | Using username 2 | 2018-06-20 00:06:26
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:06:26
DTC Client socket (30) | Creating socket. | 2018-06-20 00:06:26
DTC Client socket (30) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:06:26
SC Data - All Services | Connected to server. | 2018-06-20 00:06:26
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:26
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:26
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:26
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:26
SC Data - All Services | Received logon response. | 2018-06-20 00:06:26
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:26
DTC Client socket (30) | Socket gracefully closed by remote side. | 2018-06-20 00:06:26
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:26
DTC Client socket (30) | Received socket Close event. | 2018-06-20 00:06:26
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:26
DTC Client socket (30) | Initiating close of socket by core. | 2018-06-20 00:06:26
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:26
DTC Client socket (30) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:26
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:26
DTC Client socket (30) | Closed. | 2018-06-20 00:06:26
SC Data - All Services | Using username 2 | 2018-06-20 00:06:28
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:06:28
DTC Client socket (31) | Creating socket. | 2018-06-20 00:06:28
DTC Client socket (31) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:28
SC Data - All Services | Connected to server. | 2018-06-20 00:06:28
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:28
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:28
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:28
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:28
SC Data - All Services | Received logon response. | 2018-06-20 00:06:28
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:28
DTC Client socket (31) | Socket gracefully closed by remote side. | 2018-06-20 00:06:28
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:28
DTC Client socket (31) | Received socket Close event. | 2018-06-20 00:06:28
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:28
DTC Client socket (31) | Initiating close of socket by core. | 2018-06-20 00:06:28
DTC Client socket (31) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:28
DTC Client socket (31) | Closed. | 2018-06-20 00:06:28
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:28
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:28
SC Data - All Services | Using username 0 | 2018-06-20 00:06:30
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:06:30
DTC Client socket (32) | Creating socket. | 2018-06-20 00:06:30
DTC Client socket (32) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:06:30
SC Data - All Services | Connected to server. | 2018-06-20 00:06:30
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:30
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:30
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:30
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:30
SC Data - All Services | Received logon response. | 2018-06-20 00:06:30
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:30
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:30
DTC Client socket (32) | Socket gracefully closed by remote side. | 2018-06-20 00:06:30
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:30
DTC Client socket (32) | Received socket Close event. | 2018-06-20 00:06:30
DTC Client socket (32) | Initiating close of socket by core. | 2018-06-20 00:06:30
DTC Client socket (32) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:30
DTC Client socket (32) | Closed. | 2018-06-20 00:06:30
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:30
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:30
SC Data - All Services | Using username 0 | 2018-06-20 00:06:32
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:06:32
DTC Client socket (33) | Creating socket. | 2018-06-20 00:06:32
DTC Client socket (33) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:32
SC Data - All Services | Connected to server. | 2018-06-20 00:06:33
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:33
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:33
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:33
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:33
SC Data - All Services | Received logon response. | 2018-06-20 00:06:33
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:33
DTC Client socket (33) | Socket gracefully closed by remote side. | 2018-06-20 00:06:33
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:33
DTC Client socket (33) | Received socket Close event. | 2018-06-20 00:06:33
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:33
DTC Client socket (33) | Initiating close of socket by core. | 2018-06-20 00:06:33
DTC Client socket (33) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:33
DTC Client socket (33) | Closed. | 2018-06-20 00:06:33
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:33
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:33
SC Data - All Services | Using username 1 | 2018-06-20 00:06:35
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:06:35
DTC Client socket (34) | Creating socket. | 2018-06-20 00:06:35
DTC Client socket (34) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:06:35
SC Data - All Services | Connected to server. | 2018-06-20 00:06:35
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:35
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:35
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:35
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:35
SC Data - All Services | Received logon response. | 2018-06-20 00:06:35
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:35
DTC Client socket (34) | Socket gracefully closed by remote side. | 2018-06-20 00:06:35
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:35
DTC Client socket (34) | Received socket Close event. | 2018-06-20 00:06:35
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:35
DTC Client socket (34) | Initiating close of socket by core. | 2018-06-20 00:06:35
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:35
DTC Client socket (34) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:35
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:35
DTC Client socket (34) | Closed. | 2018-06-20 00:06:35
SC Data - All Services | Using username 1 | 2018-06-20 00:06:37
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:06:37
DTC Client socket (35) | Creating socket. | 2018-06-20 00:06:37
DTC Client socket (35) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:37
SC Data - All Services | Connected to server. | 2018-06-20 00:06:37
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:37
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:37
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:37
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:37
SC Data - All Services | Received logon response. | 2018-06-20 00:06:37
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:37
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:37
DTC Client socket (35) | Socket gracefully closed by remote side. | 2018-06-20 00:06:37
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:37
DTC Client socket (35) | Received socket Close event. | 2018-06-20 00:06:37
DTC Client socket (35) | Initiating close of socket by core. | 2018-06-20 00:06:37
DTC Client socket (35) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:37
DTC Client socket (35) | Closed. | 2018-06-20 00:06:37
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:37
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:37
SC Data - All Services | Using username 2 | 2018-06-20 00:06:39
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:06:39
DTC Client socket (36) | Creating socket. | 2018-06-20 00:06:39
DTC Client socket (36) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:06:39
SC Data - All Services | Connected to server. | 2018-06-20 00:06:39
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:39
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:39
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:39
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:39
SC Data - All Services | Received logon response. | 2018-06-20 00:06:39
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:39
DTC Client socket (36) | Socket gracefully closed by remote side. | 2018-06-20 00:06:39
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:39
DTC Client socket (36) | Received socket Close event. | 2018-06-20 00:06:39
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:39
DTC Client socket (36) | Initiating close of socket by core. | 2018-06-20 00:06:39
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:39
DTC Client socket (36) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:39
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:39
DTC Client socket (36) | Closed. | 2018-06-20 00:06:39
SC Data - All Services | Using username 2 | 2018-06-20 00:06:41
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:06:41
DTC Client socket (37) | Creating socket. | 2018-06-20 00:06:41
DTC Client socket (37) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:41
SC Data - All Services | Connected to server. | 2018-06-20 00:06:41
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:41
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:41
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:42
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:42
SC Data - All Services | Received logon response. | 2018-06-20 00:06:42
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:42
DTC Client socket (37) | Socket gracefully closed by remote side. | 2018-06-20 00:06:42
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:42
DTC Client socket (37) | Received socket Close event. | 2018-06-20 00:06:42
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:42
DTC Client socket (37) | Initiating close of socket by core. | 2018-06-20 00:06:42
DTC Client socket (37) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:42
DTC Client socket (37) | Closed. | 2018-06-20 00:06:42
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:42
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:42
SC Data - All Services | Using username 0 | 2018-06-20 00:06:44
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:06:44
DTC Client socket (38) | Creating socket. | 2018-06-20 00:06:44
DTC Client socket (38) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:06:44
SC Data - All Services | Connected to server. | 2018-06-20 00:06:44
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:44
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:44
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:44
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:44
SC Data - All Services | Received logon response. | 2018-06-20 00:06:44
DTC Client socket (38) | Socket gracefully closed by remote side. | 2018-06-20 00:06:44
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:44
DTC Client socket (38) | Received socket Close event. | 2018-06-20 00:06:44
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:44
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:44
DTC Client socket (38) | Initiating close of socket by core. | 2018-06-20 00:06:44
DTC Client socket (38) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:44
DTC Client socket (38) | Closed. | 2018-06-20 00:06:44
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:44
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:44
SC Data - All Services | Using username 0 | 2018-06-20 00:06:46
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:06:46
DTC Client socket (39) | Creating socket. | 2018-06-20 00:06:46
DTC Client socket (39) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:46
SC Data - All Services | Connected to server. | 2018-06-20 00:06:46
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:46
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:46
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:46
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:46
SC Data - All Services | Received logon response. | 2018-06-20 00:06:46
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:46
DTC Client socket (39) | Socket gracefully closed by remote side. | 2018-06-20 00:06:46
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:46
DTC Client socket (39) | Received socket Close event. | 2018-06-20 00:06:46
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:46
DTC Client socket (39) | Initiating close of socket by core. | 2018-06-20 00:06:46
DTC Client socket (39) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:46
DTC Client socket (39) | Closed. | 2018-06-20 00:06:46
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:46
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:46
SC Data - All Services | Using username 1 | 2018-06-20 00:06:48
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:06:48
DTC Client socket (40) | Creating socket. | 2018-06-20 00:06:48
DTC Client socket (40) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:06:48
SC Data - All Services | Connected to server. | 2018-06-20 00:06:48
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:48
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:48
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:48
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:48
SC Data - All Services | Received logon response. | 2018-06-20 00:06:48
DTC Client socket (40) | Socket gracefully closed by remote side. | 2018-06-20 00:06:48
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:48
DTC Client socket (40) | Received socket Close event. | 2018-06-20 00:06:48
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:48
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:48
DTC Client socket (40) | Initiating close of socket by core. | 2018-06-20 00:06:48
DTC Client socket (40) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:48
DTC Client socket (40) | Closed. | 2018-06-20 00:06:48
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:48
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:48
SC Data - All Services | Using username 1 | 2018-06-20 00:06:50
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:06:50
DTC Client socket (41) | Creating socket. | 2018-06-20 00:06:50
DTC Client socket (41) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:50
SC Data - All Services | Connected to server. | 2018-06-20 00:06:50
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:50
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:50
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:51
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:51
SC Data - All Services | Received logon response. | 2018-06-20 00:06:51
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:51
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:51
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:51
DTC Client socket (41) | Socket gracefully closed by remote side. | 2018-06-20 00:06:51
DTC Client socket (41) | Received socket Close event. | 2018-06-20 00:06:51
DTC Client socket (41) | Initiating close of socket by core. | 2018-06-20 00:06:51
DTC Client socket (41) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:51
DTC Client socket (41) | Closed. | 2018-06-20 00:06:51
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:51
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:51
SC Data - All Services | Using username 2 | 2018-06-20 00:06:53
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:06:53
DTC Client socket (42) | Creating socket. | 2018-06-20 00:06:53
DTC Client socket (42) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:06:53
SC Data - All Services | Connected to server. | 2018-06-20 00:06:53
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:53
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:53
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:53
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:53
SC Data - All Services | Received logon response. | 2018-06-20 00:06:53
DTC Client socket (42) | Socket gracefully closed by remote side. | 2018-06-20 00:06:53
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:53
DTC Client socket (42) | Received socket Close event. | 2018-06-20 00:06:53
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:53
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:53
DTC Client socket (42) | Initiating close of socket by core. | 2018-06-20 00:06:53
DTC Client socket (42) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:53
DTC Client socket (42) | Closed. | 2018-06-20 00:06:53
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:53
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:53
SC Data - All Services | Using username 2 | 2018-06-20 00:06:55
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:06:55
DTC Client socket (43) | Creating socket. | 2018-06-20 00:06:55
DTC Client socket (43) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:55
SC Data - All Services | Connected to server. | 2018-06-20 00:06:55
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:55
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:55
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:55
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:55
SC Data - All Services | Received logon response. | 2018-06-20 00:06:55
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:55
DTC Client socket (43) | Socket gracefully closed by remote side. | 2018-06-20 00:06:55
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:55
DTC Client socket (43) | Received socket Close event. | 2018-06-20 00:06:55
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:55
DTC Client socket (43) | Initiating close of socket by core. | 2018-06-20 00:06:55
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:55
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:55
DTC Client socket (43) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:55
DTC Client socket (43) | Closed. | 2018-06-20 00:06:55
HD Request # 4 | Downloading Intraday chart data for ASTC to the file ASTC.scid. Service: equities.us | 2018-06-20 00:06:55
HD Request # 4 | Download start date-time: 2018-06-19 16:59:32.000 | 2018-06-20 00:06:55
HD Request # 4 | Using server: ds7.sierracharts.com port 10149 | 2018-06-20 00:06:55
Socket (44) | Creating socket. | 2018-06-20 00:06:55
Socket (44) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:55
HD Request # 4 | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:55
HD Request # 4 | Sending historical data logon request message. | 2018-06-20 00:06:55
HD Request # 4 | Requesting Intraday data. Start date-time: 2018-06-19 16:59:32. Record interval: 1. Symbol: ASTC | 2018-06-20 00:06:56
HD Request # 4 | Decompressing data. | 2018-06-20 00:06:56
HD Request # 4 | Receiving Intraday data for ASTC starting at 2018-06-19 16:59:32 | 2018-06-20 00:06:56
HD Request # 4 | Timestamp of first Intraday data file record written: 2018-06-19 16:59:32 | 2018-06-20 00:06:56
Socket (44) | Initiating close of socket by core. | 2018-06-20 00:06:56
Socket (44) | Shutdown started. Waiting for graceful close. | 2018-06-20 00:06:56
Historical data download thread signaled to stop. | 2018-06-20 00:06:56
HD Request # 4 | Received 1 record from 2018-06-19 16:59:32 to 2018-06-19 16:59:32 (0.0 seconds) and wrote 1 record for ASTC | 2018-06-20 00:06:56
HD Request # 4 | Completion time: 0s | 2018-06-20 00:06:56
HD Request # 4 | Intraday data download complete for ASTC. Unique request ID: 3 | 2018-06-20 00:06:56
Removed historical data download ID 3 | 2018-06-20 00:06:56
Real-time Intraday chart data file updates started for ASTC | 2018-06-20 00:06:56
Opened cached Intraday file: C:\SierraChart2\Data\ASTC.scid | 2018-06-20 00:06:56
Intraday chart data file opened for ASTC | 2018-06-20 00:06:56
Socket (44) | Socket gracefully closed by remote side. | 2018-06-20 00:06:56
Socket (44) | Closed. | 2018-06-20 00:06:56
SC Data - All Services | Using username 0 | 2018-06-20 00:06:57
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:06:57
DTC Client socket (45) | Creating socket. | 2018-06-20 00:06:57
DTC Client socket (45) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:06:57
SC Data - All Services | Connected to server. | 2018-06-20 00:06:57
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:57
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:57
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:06:57
SC Data - All Services | Sending logon request message. | 2018-06-20 00:06:57
SC Data - All Services | Received logon response. | 2018-06-20 00:06:57
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:06:57
DTC Client socket (45) | Socket gracefully closed by remote side. | 2018-06-20 00:06:57
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:06:57
DTC Client socket (45) | Received socket Close event. | 2018-06-20 00:06:57
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:06:57
DTC Client socket (45) | Initiating close of socket by core. | 2018-06-20 00:06:57
DTC Client socket (45) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:06:57
DTC Client socket (45) | Closed. | 2018-06-20 00:06:57
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:06:57
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:06:57
SC Data - All Services | Using username 0 | 2018-06-20 00:06:59
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:06:59
DTC Client socket (46) | Creating socket. | 2018-06-20 00:06:59
DTC Client socket (46) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:06:59
SC Data - All Services | Connected to server. | 2018-06-20 00:06:59
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:06:59
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:06:59
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:00
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:00
SC Data - All Services | Received logon response. | 2018-06-20 00:07:00
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:00
DTC Client socket (46) | Socket gracefully closed by remote side. | 2018-06-20 00:07:00
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:00
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:00
DTC Client socket (46) | Received socket Close event. | 2018-06-20 00:07:00
DTC Client socket (46) | Initiating close of socket by core. | 2018-06-20 00:07:00
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:00
DTC Client socket (46) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:00
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:00
DTC Client socket (46) | Closed. | 2018-06-20 00:07:00
File >> Disconnect selected. | 2018-06-20 00:07:02
Socket (14) | Initiating close of socket by core. | 2018-06-20 00:07:02
Socket (14) | Shutdown started. Waiting for graceful close. | 2018-06-20 00:07:02
Socket (14) | Socket gracefully closed by remote side. | 2018-06-20 00:07:02
Socket (14) | Closed. | 2018-06-20 00:07:02
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:02
Interactive Brokers | Disconnected. | 2018-06-20 00:07:02
Interactive Brokers | Connecting to 127.0.0.1:7495 | 2018-06-20 00:07:02
Starting TWS auto-login thread. | 2018-06-20 00:07:02
Socket (47) | Creating socket. | 2018-06-20 00:07:02
Socket (47) | Connecting to IP: 127.0.0.1. | 2018-06-20 00:07:02
TWS auto-login thread ending. | 2018-06-20 00:07:02
Interactive Brokers | Sending API sign: API | 2018-06-20 00:07:03
Interactive Brokers | Sending client version: v100..136. Waiting for acceptance. | 2018-06-20 00:07:03
Interactive Brokers | TWS server version: 118 | 2018-06-20 00:07:04
Interactive Brokers | TWS time: 20180620 00:07:04 PST | 2018-06-20 00:07:04
Interactive Brokers | Connected. Sending Start API command. | 2018-06-20 00:07:04
Interactive Brokers | Waiting for account information. | 2018-06-20 00:07:04
IB Account information received. | 2018-06-20 00:07:05
Interactive Brokers | Received 1 Trade Accounts from TWS. | 2018-06-20 00:07:05
Interactive Brokers | Connected to Demo or Simulated account. | 2018-06-20 00:07:05
Interactive Brokers | Year-Month last connected to Live account: 2018-06 | 2018-06-20 00:07:05
Interactive Brokers | Connected to data and trading server. | 2018-06-20 00:07:05
Next valid order ID: 366 | 2018-06-20 00:07:05
Message from IB: Market data farm connection is OK:usfarm. IB Error Code: 2104. Request ID: -1. | 2018-06-20 00:07:05
Message from IB: HMDS data farm connection is OK:ushmds. IB Error Code: 2106. Request ID: -1. | 2018-06-20 00:07:05
Mapping ASTC to ASTC. Service code: equities.us | 2018-06-20 00:07:05
SC Data - All Services | Starting real-time market data updates for: ASTC. ID: 1 | 2018-06-20 00:07:05
SC Data - All Services | Using username 1 | 2018-06-20 00:07:05
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:07:05
SC Data - All Services | Requesting security definition data for: ASTC. ID: 1 | 2018-06-20 00:07:05
Intraday data recording state for symbol ASTC is set to download 'Pending'. | 2018-06-20 00:07:05
DTC Client socket (48) | Creating socket. | 2018-06-20 00:07:05
DTC Client socket (48) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:07:05
Delaying start of download for ASTC | 2018-06-20 00:07:05
SC Data - All Services | Connected to server. | 2018-06-20 00:07:05
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:07:05
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:07:05
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:05
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:05
SC Data - All Services | Received logon response. | 2018-06-20 00:07:05
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:05
DTC Client socket (48) | Socket gracefully closed by remote side. | 2018-06-20 00:07:05
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:05
DTC Client socket (48) | Received socket Close event. | 2018-06-20 00:07:05
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:05
DTC Client socket (48) | Initiating close of socket by core. | 2018-06-20 00:07:05
DTC Client socket (48) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:05
DTC Client socket (48) | Closed. | 2018-06-20 00:07:05
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:05
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:05
SC Data - All Services | Using username 1 | 2018-06-20 00:07:07
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:07:07
DTC Client socket (49) | Creating socket. | 2018-06-20 00:07:07
DTC Client socket (49) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:07:07
SC Data - All Services | Connected to server. | 2018-06-20 00:07:07
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:07:07
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:07:07
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:08
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:08
SC Data - All Services | Received logon response. | 2018-06-20 00:07:08
DTC Client socket (49) | Socket gracefully closed by remote side. | 2018-06-20 00:07:08
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:08
DTC Client socket (49) | Received socket Close event. | 2018-06-20 00:07:08
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:08
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:08
DTC Client socket (49) | Initiating close of socket by core. | 2018-06-20 00:07:08
DTC Client socket (49) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:08
DTC Client socket (49) | Closed. | 2018-06-20 00:07:08
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:08
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:08
SC Data - All Services | Using username 2 | 2018-06-20 00:07:10
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:07:10
DTC Client socket (50) | Creating socket. | 2018-06-20 00:07:10
DTC Client socket (50) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:07:10
SC Data - All Services | Connected to server. | 2018-06-20 00:07:10
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:07:10
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:07:10
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:10
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:10
SC Data - All Services | Received logon response. | 2018-06-20 00:07:10
DTC Client socket (50) | Socket gracefully closed by remote side. | 2018-06-20 00:07:10
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:10
DTC Client socket (50) | Received socket Close event. | 2018-06-20 00:07:10
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:10
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:10
DTC Client socket (50) | Initiating close of socket by core. | 2018-06-20 00:07:10
DTC Client socket (50) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:10
DTC Client socket (50) | Closed. | 2018-06-20 00:07:10
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:10
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:10
Interactive Brokers | Requesting Trade Positions snapshot and updates (IB account data updates) for account: DU10* | 2018-06-20 00:07:10
Interactive Brokers | Received Trade Positions download end message for account DU10* | 2018-06-20 00:07:10
SC Data - All Services | Using username 2 | 2018-06-20 00:07:12
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:07:12
DTC Client socket (51) | Creating socket. | 2018-06-20 00:07:12
DTC Client socket (51) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:07:12
SC Data - All Services | Connected to server. | 2018-06-20 00:07:12
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:07:12
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:07:12
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:12
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:12
SC Data - All Services | Received logon response. | 2018-06-20 00:07:12
DTC Client socket (51) | Socket gracefully closed by remote side. | 2018-06-20 00:07:12
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:12
DTC Client socket (51) | Received socket Close event. | 2018-06-20 00:07:12
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:12
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:12
DTC Client socket (51) | Initiating close of socket by core. | 2018-06-20 00:07:12
DTC Client socket (51) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:12
DTC Client socket (51) | Closed. | 2018-06-20 00:07:12
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:12
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:12
SC Data - All Services | Using username 0 | 2018-06-20 00:07:14
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:07:14
DTC Client socket (53) | Creating socket. | 2018-06-20 00:07:14
DTC Client socket (53) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:07:14
SC Data - All Services | Connected to server. | 2018-06-20 00:07:14
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:07:14
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:07:14
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:16
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:16
SC Data - All Services | Received logon response. | 2018-06-20 00:07:16
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:16
DTC Client socket (53) | Socket gracefully closed by remote side. | 2018-06-20 00:07:16
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:16
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:16
DTC Client socket (53) | Received socket Close event. | 2018-06-20 00:07:16
DTC Client socket (53) | Initiating close of socket by core. | 2018-06-20 00:07:16
DTC Client socket (53) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:16
DTC Client socket (53) | Closed. | 2018-06-20 00:07:16
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:16
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:16
SC Data - All Services | Using username 0 | 2018-06-20 00:07:18
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:07:18
DTC Client socket (54) | Creating socket. | 2018-06-20 00:07:18
DTC Client socket (54) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:07:18
SC Data - All Services | Connected to server. | 2018-06-20 00:07:18
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:07:18
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:07:18
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:19
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:19
SC Data - All Services | Received logon response. | 2018-06-20 00:07:19
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:19
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:19
DTC Client socket (54) | Socket gracefully closed by remote side. | 2018-06-20 00:07:19
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:19
DTC Client socket (54) | Received socket Close event. | 2018-06-20 00:07:19
DTC Client socket (54) | Initiating close of socket by core. | 2018-06-20 00:07:19
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:19
DTC Client socket (54) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:19
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:19
DTC Client socket (54) | Closed. | 2018-06-20 00:07:19
SC Data - All Services | Using username 1 | 2018-06-20 00:07:21
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:07:21
DTC Client socket (55) | Creating socket. | 2018-06-20 00:07:21
DTC Client socket (55) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:07:21
SC Data - All Services | Connected to server. | 2018-06-20 00:07:21
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:07:21
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:07:21
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:21
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:21
SC Data - All Services | Received logon response. | 2018-06-20 00:07:21
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:21
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:21
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:21
DTC Client socket (55) | Socket gracefully closed by remote side. | 2018-06-20 00:07:21
DTC Client socket (55) | Received socket Close event. | 2018-06-20 00:07:21
DTC Client socket (55) | Initiating close of socket by core. | 2018-06-20 00:07:21
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:21
DTC Client socket (55) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:21
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:21
DTC Client socket (55) | Closed. | 2018-06-20 00:07:21
SC Data - All Services | Using username 1 | 2018-06-20 00:07:23
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:07:23
DTC Client socket (56) | Creating socket. | 2018-06-20 00:07:23
DTC Client socket (56) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:07:23
SC Data - All Services | Connected to server. | 2018-06-20 00:07:23
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:07:23
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:07:23
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:23
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:23
SC Data - All Services | Received logon response. | 2018-06-20 00:07:23
DTC Client socket (56) | Socket gracefully closed by remote side. | 2018-06-20 00:07:23
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:23
DTC Client socket (56) | Received socket Close event. | 2018-06-20 00:07:23
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:23
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:23
DTC Client socket (56) | Initiating close of socket by core. | 2018-06-20 00:07:23
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:23
DTC Client socket (56) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:23
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:23
DTC Client socket (56) | Closed. | 2018-06-20 00:07:23
SC Data - All Services | Using username 2 | 2018-06-20 00:07:25
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:07:25
DTC Client socket (57) | Creating socket. | 2018-06-20 00:07:25
DTC Client socket (57) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:07:25
SC Data - All Services | Connected to server. | 2018-06-20 00:07:25
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:07:25
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:07:25
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:25
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:25
SC Data - All Services | Received logon response. | 2018-06-20 00:07:25
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:25
DTC Client socket (57) | Socket gracefully closed by remote side. | 2018-06-20 00:07:25
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:25
DTC Client socket (57) | Received socket Close event. | 2018-06-20 00:07:25
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:25
DTC Client socket (57) | Initiating close of socket by core. | 2018-06-20 00:07:25
DTC Client socket (57) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:25
DTC Client socket (57) | Closed. | 2018-06-20 00:07:25
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:25
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:25
SC Data - All Services | Using username 2 | 2018-06-20 00:07:27
SC Data - All Services | Connecting to the server ds7.sierracharts.com. Port 10046 | 2018-06-20 00:07:27
DTC Client socket (58) | Creating socket. | 2018-06-20 00:07:27
DTC Client socket (58) | Connecting to IP: 8.18.161.133. | 2018-06-20 00:07:27
SC Data - All Services | Connected to server. | 2018-06-20 00:07:27
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:07:27
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:07:27
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:28
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:28
SC Data - All Services | Received logon response. | 2018-06-20 00:07:28
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:28
DTC Client socket (58) | Socket gracefully closed by remote side. | 2018-06-20 00:07:28
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:28
DTC Client socket (58) | Received socket Close event. | 2018-06-20 00:07:28
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:28
DTC Client socket (58) | Initiating close of socket by core. | 2018-06-20 00:07:28
DTC Client socket (58) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:28
DTC Client socket (58) | Closed. | 2018-06-20 00:07:28
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:28
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:28
SC Data - All Services | Using username 0 | 2018-06-20 00:07:30
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10047 | 2018-06-20 00:07:30
DTC Client socket (59) | Creating socket. | 2018-06-20 00:07:30
DTC Client socket (59) | Connecting to IP: 8.18.161.135. | 2018-06-20 00:07:30
SC Data - All Services | Connected to server. | 2018-06-20 00:07:30
SC Data - All Services | Starting socket receive thread. | 2018-06-20 00:07:30
SC Data - All Services | Sending encoding request to server: Binary VLS | 2018-06-20 00:07:30
SC Data - All Services | Setting DTC encoding to Binary VLS | 2018-06-20 00:07:30
SC Data - All Services | Sending logon request message. | 2018-06-20 00:07:30
SC Data - All Services | Received logon response. | 2018-06-20 00:07:30
SC Data - All Services | Server Name: SC Real-Time Server. | 2018-06-20 00:07:30
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2018-06-20 00:07:30
DTC Client socket (59) | Socket gracefully closed by remote side. | 2018-06-20 00:07:30
SC Data - All Services | Logon error received from server: Limited to one connection per username for the requested data source. | 2018-06-20 00:07:30
DTC Client socket (59) | Received socket Close event. | 2018-06-20 00:07:30
DTC Client socket (59) | Initiating close of socket by core. | 2018-06-20 00:07:30
DTC Client socket (59) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-06-20 00:07:30
DTC Client socket (59) | Closed. | 2018-06-20 00:07:30
SC Data - All Services | Disconnected from the server. | 2018-06-20 00:07:30
SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2018-06-20 00:07:30
I received this error message late tonite, please advise. I recently added a third connection.
[2018-06-20 07:55:26]
Based on what we see, all three usernames are being used and you are trying to use a fourth one.
